small hole in axel boot
Old Sep 30, 2009 | 02:23 PM
worksevo89's Avatar
Registered User
So when i was doing my clutch change this last end i notice that there was a tiny hole the front passenger axel boot. there is still grease in there. Should I be very concerned? is there a simple fix for this or do i really need a new axel? Thanks
Old Sep 30, 2009 | 03:21 PM
worksevo89's Avatar
Registered User
Bump
Old Sep 30, 2009 | 03:29 PM
localtoys73's Avatar
you should get it fixed while there is grease still in there once it runs out and it will then you will need a new joint
Old Sep 30, 2009 | 03:31 PM
worksevo89's Avatar
Registered User
How can i have it fixed?
Old Sep 30, 2009 | 03:48 PM
YogSaahoth's Avatar
Veteran: Army
you can buy new boots but the labor to change them is a biiiiiiiitch. u would have to remove the entire half shaft and use a special tool to clamp the new boot on. u would have to do some searching or get input from other members, but u may be able to just patch the hole. even if u successfully patch it up, thats more of a tmeporary solution. i dont think there's any easy way out. i just replaced both of my front axles because the inner cv boots were leaking on both shafts. its easier to replace the entire shaft than to replace a boot. goodluck man
Old Sep 30, 2009 | 03:58 PM
worksevo89's Avatar
Registered User
i was thinking about patching it until i have money for a new axel. what could i patch it with?
Old Sep 30, 2009 | 04:14 PM
Protostar1's Avatar
I tore one of mine, I think with parts and labor it was somewhere around $250-300. If you are going to patch it (I would recommend you just get it fixed...) you need something flexible and realistically nothing will really work except, well the boot, so you might as well use some duct tape...
Old Sep 30, 2009 | 04:24 PM
worksevo89's Avatar
Registered User
seems getto, but i guess its better then nothing. im going to fix it as soon as i have the money. I just changed the clutch so i need to save money again.
Old Sep 30, 2009 | 05:08 PM
barneyb's Avatar
I've never changed an axle boot on my Evo but I did a few on my DSM and never thought it was that big of deal. The boots for my DSM were pricey through Mitsu but aftermarket boots were available at reasonable cost. You do need a special pliers for the clamp.
Old Sep 30, 2009 | 05:11 PM
edardnaekim's Avatar
I would just get a new half shaft. It cost me about 90 bucks at a local autoparts store.
Old Oct 2, 2009 | 08:43 AM
worksevo89's Avatar
Registered User
So I went to one of our local high end shops and the guy there said it wasnt to bad and put some of this black rubber stuff on it as a patch. What do you guys think?
Old Oct 2, 2009 | 08:57 AM
benniboi08's Avatar
yeah seems fine to me. I have the exact same rubber compound that adheres to materials with heat and a bit of pressure. its hard to explain. I would say just keep a close eye on it until you have the money to fix the boot the right way. After all the boot (rubber part) does not rotate it just extends and contracts with you steering left and right. best of luck
REV.olution
Apr 25, 2015 06:08 AM
evodziobak
Feb 25, 2015 11:17 PM
brunz44
Aug 29, 2013 07:32 PM
willseph
Jul 1, 2008 01:36 PM
