Overhearing Issue
Old Oct 1, 2009 | 09:02 AM
Emperor 4g63's Avatar
Overheating Issue
My car over heats after driving for 2-3miles. The car seems to be driving fine after driving 2-3 mile and starts to overheat. What can cause this?
Old Oct 1, 2009 | 09:08 AM
Evoryder's Avatar
waterpump, headgasket failure, thermostat failure, no coolant, bad radiator, radiator fan not turning on.
Old Oct 1, 2009 | 09:21 AM
Macaroni's Avatar
^ Check all of these. Obviously do the easiest first though... I went through everything except for the headgasket to find out it was my water pump.
Old Oct 1, 2009 | 09:49 AM
maperformance's Avatar
Serpentine Belt also may be broke or off.
Old Oct 1, 2009 | 11:00 AM
ZFRED10's Avatar
Same thing happened to me. Ended up being my thermostat which is an easy replacement. Then again it could be other things to. I'd check the thermostat first.
Old Oct 1, 2009 | 11:28 AM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Same thing would happen to a buddy of mine turned out to be the head studs stretched and air was getting past the head gasket
Old Oct 1, 2009 | 02:48 PM
barneyb's Avatar
Just curious - what was wrong with your water pump?
Old Oct 1, 2009 | 02:49 PM
jhanksevo's Avatar
check your coolant level first and foremost
Old Oct 1, 2009 | 08:04 PM
Macaroni's Avatar
Not sure. At about 60k miles it went out on me. My overheating problem was very sporadic... Sometimes it would and sometimes it wouldn't. Regardless of if I were in traffic or cruising down the interstate.
Old Oct 2, 2009 | 04:26 AM
I replaced thermostat that wasn't the issue...I guess water pump is next
Old Oct 2, 2009 | 05:37 AM
Macaroni's Avatar
Check to make sure there's no air in the system and that the fans are turning on. Water pump replacement isn't exactly the easiest... You might as well get a new timing belt, tensioner, and idler pulley if your going to be replacing it.
Yatchaulin
Jan 13, 2015 07:44 PM
Thugline
18
Jan 25, 2014 06:41 AM
mr 2.3 evo
17
Nov 14, 2011 09:21 PM
evoballer
Feb 28, 2011 06:20 PM
stefano
Midwest Region
Aug 25, 2010 08:07 PM
