car is pissin me off !!
Old Oct 12, 2009 | 02:29 PM
dinok's Avatar
so i have a 06 evo rs with
mbc
hks intake suction kit
tbe
255 fuel pump
iveytune on 21 lbs
lately my idle has been dropping and picking up again from time to time when im at a complete stop ! would i by any chance need a re-tune ?? or is it something else that needs to be looked at ??
any insight back would be great !
Old Oct 12, 2009 | 02:32 PM
buchnerj's Avatar
does it like gradually rev when at a stop light or standstill then bottom out? Or are you saying the idle changes and can get consistently low at points but stays low?
Old Oct 12, 2009 | 02:33 PM
Liqquid's Avatar
boost leak test (for vacuum leaks) and maybe clean the maf first...
Old Oct 12, 2009 | 02:38 PM
Lancerguy'03's Avatar
+1 on the boost leak test.
how long have you been on the tune?
Old Oct 12, 2009 | 02:43 PM
JDMevoBOOST's Avatar
Are you turning the steering wheel when the idle drops? Because that is normal.
Old Oct 12, 2009 | 02:49 PM
erald01's Avatar
its no boost leak thats normal...sometimes mine does that when i come to a quick full stop, i tried solving it with an HKS gorunding kit, but it will still do it now and then..
Old Oct 12, 2009 | 02:50 PM
JakeTheVIII's Avatar
Seems like my car does this every time I disconnect the battery/reset it. You come to a stop, and the rpms dip and raise.
Old Oct 12, 2009 | 02:51 PM
kwanza's Avatar
IAC valve on the throttle body can cause this as well. My car would fluctuate and stall out.
You can check this by removing it from the throttle body, 3 or 4 screws.
With it removed from the throttlebody while it is hooked up, have someone turn the key to on, but do not start the car. The valve should open up, if it does not, time to replace. This valve is used to modulate throttle while in idle.
Old Oct 13, 2009 | 12:42 PM
dinok's Avatar
when im at a complete stop for about 30 seconds it will dip and rise dip and rise i got a tune about 4 months ago but it was a mild tune, im getting a dynoflash hopefully the problem will go away !
Old Oct 13, 2009 | 12:52 PM
gsrboi80's Avatar
Yea common with alot of cars EVOS are notorious. It takes the ECU a while relearn idle
jamrockevo8
Oct 26, 2014 04:55 PM
jnelson4311
Apr 23, 2013 10:23 PM
OfaceGrimmins
Aug 30, 2012 11:11 AM
240sxzenki
Jan 26, 2012 01:35 PM
EndlessRed
Evo X How Tos / Installations
56
Aug 12, 2010 01:53 PM
