Connecting brass fitting to intake pipe
Old Oct 13, 2009 | 08:55 PM
McDougal's Avatar
What should I use in terms of a sealant? Any ideas? The fitting wouldn't thread into the pipe. Kind of stripped the threads. It sits in there pretty tight but it needs something to secure it.
Old Oct 13, 2009 | 09:03 PM
Rex915's Avatar
Id like to knw too
Old Oct 13, 2009 | 10:02 PM
chaotichoax's Avatar
loctite blue
Old Oct 13, 2009 | 10:22 PM
JohnnyTSi's Avatar
JB-Weld JB-KWIK works excellent, it seals the fitting and will add some support to keep the fitting in a thin walled pipe.
It also is reasonably easy to remove if needed.
John-
Old Oct 14, 2009 | 07:41 AM
97TSiAWD's Avatar
+1. JB-weld would be what I use.
Old Oct 14, 2009 | 08:06 AM
McDougal's Avatar
Thanks for the responses. Much appreciated. I figured something like JB Weld would work considering there isn't boost running through the intake tube.
Old Oct 14, 2009 | 09:27 AM
McDougal's Avatar
I made an attempt to source some stainless fittings locally, but the only place I could find wanted like $50 for two fittings. I am just going to keep the brass and throw some JB Weld or Loctite Blue on there. If it doesn't work I will get some stainless fittings and have them welded on, but I think the JB method should work just fine.
Crosxs
May 20, 2025 06:14 AM
xRoguex
26
Mar 25, 2018 01:51 PM
markae86
Sep 3, 2012 10:12 AM
Tsurugi-san
Aug 11, 2007 09:49 PM
Graphite_MR
13
Sep 17, 2006 05:28 PM
