Heater not working after radiator flush
So i just purchased a 03 Evo 8, and i'm have function in the blower but the cold to hot knob tightens only when i'm close to max heat, but still no heat, i've read about a gear function that may go out somewhere in the foot well area by the gas pedal. where/what exactly am i looking for and will i be able to see it? and with the t-stats, if i do replace that should i do a coolant flush and place new coolant to water combo ? if so what should i do 40/60? 30/70? i do live in alaska. and winter is coming.
As for the antifreeze mix you need - buy a jug of antifreeze and look on the side of the jug for the coldest temperature you expect to ever experience this winter and use the mixture they recommend.
Video Link: http://www.youtube.com/watch?v=vcG20LmRZFU As for the antifreeze mix you need - buy a jug of antifreeze and look on the side of the jug for the coldest temperature you expect to ever experience this winter and use the mixture they recommend.
Thanks barneyb
Turns out i was low on coolant and replenishing it did it to get the heater back into working status appreciate the feedback along with the vid link ;-)
Astro_Train
10
May 30, 2013 02:33 PM
sgtr275
Apr 9, 2011 03:47 AM
to update, my door gear went bad and it was burped the entire time!
