HKS SSQV not working
Old Oct 25, 2009 | 08:46 AM
Armyevo2003's Avatar
I just put my car back together yesterday for the winter and found out my HKS SSQV is not working at all! It doesn't open to release the air to atmosphere. I had a tomei turbo tuned on E-85 for the summer and now I put the stock turbo back in with the stock ecu so I can run premium fuel for the winter months here in Iowa. I pulled the BOV apart and the valve does push in but feels a bit hard and slow to react. Does anyone know if I need to clean it out or is it hopeless and I have to fork out another $250 for a new one? I bought this one back in November of 2006 and put 40K miles on my Evo since. A little help please.
Old Oct 25, 2009 | 01:18 PM
lst4g63's Avatar
i dont know about cleaning it but hks sells repair kits for the ssqv. my just gave out also.
Old Oct 25, 2009 | 07:50 PM
wynn456's Avatar
had the ssqv for 2years and it failed. i would just spend the money and get a tial you will be much happier with the tial
Old Oct 25, 2009 | 09:20 PM
Well I took it apart and cleaned it by removing all those little allen key headed bolts. They were all very loose so THAT fixed the boost leak I was looking for a month ago. Idiot me I know...but I tightened them all down and the valve works sometimes and sometimes not. Where can I search for the repair kit? I gave it a google search and did not find anything. I'm thinking I am gonna go buy a new one if need be, as I have all new IC piping and its only for a HKS BOV, so the tial is outta the question.
Old Oct 25, 2009 | 09:21 PM
I could be stressing too much and over looking though...does anyone know maybe by chance why it doesn't open? help please
Old Oct 25, 2009 | 09:59 PM
lst4g63's Avatar
I should have been more clear. Its not a repair kit but you can buy most if not all the components of the bov here.
http://www.hksusa.com/categories/?id=1063
My failed as i said and Ive yet to fix it, im debating going with something else cause while researching mine i did run across a lot of others (people) that seem to have experienced failures in theirs as well; but at the moment fixing it is a lot cheaper.
Old Oct 25, 2009 | 10:06 PM
Thanks...I am gonna check it out and get back to you. Also I took it off and I am in the process of recleaning everything and making sure everything moves as it should...errrr trying at least.
Old Oct 25, 2009 | 11:07 PM
project_skyline's Avatar
Why did you switch turbo's just cause of winter???
I suggest a new BOV, if your stock MAF and not recirculating then your losing boost recovery time and shooting raw fuel after shifts or throttle lifts.
I honestly don't know how anyone can stand that thing, its the most annoying BOV ever created IMO.
APS twin vent rock on.
Old Oct 26, 2009 | 01:13 AM
Fast_Freddie's Avatar
Veteran: Navy
That and the extreme bucking that is induced with this BOV is dangerous... trust me, when i bought my car it had one on it.
Old Oct 26, 2009 | 06:15 AM
I never had any "extreme bucking" from the car or anything. And I got the valve cause it didn't leak under any boost level. Even when I had my tomei arms turbo on there boosting 30 psi on E-85. I live in iowa and the winters are very cold here so I just switched my turbo and ecu back to stock so I wouldn't have to fork out another 500 to get my AEM retuned on 93 oct. It was just easier to swap that stuff back for the winter as a couple weeks ago i couldn't get my car to start as it was 33 degrees outside. So my car sat at work for 2 days until it warmed up.
novaspyder87
Jun 7, 2012 09:30 PM
o0oz
Nov 19, 2011 08:06 AM
matizzay
Nov 3, 2011 07:51 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
3gEclipseTurbo
Nov 9, 2009 11:38 AM
