BR, 2.4, high hp/high rpm build?
Old Jun 16, 2010 | 01:50 PM
  #286
RSMike's Avatar
Originally Posted by 94AWDcoupe
Ceramic coating is a heat barrier. So it would be good on top side of piston to sheild it from combustion temp. On bottom side it would be bad. The bottom needs to shed as much heat as possible. From what I have seen ceramic coated piston tops are like snake oil. It works but from What I have seen it doesnt stay on. combustion chamber is too violent. okay for drag car but on a streett car it will burn off after a few thousand miles.
Are there different grades of Ceramic coatings though? i was planning on doing my piston crowns, CC's and exhaust and intake ports with Ceramic heat barrier coatings for my everyday street car.
The guy at HPC (high performance coatings) said it would only flake off it there was very heavy detonation and there was pitting on the head or piston...
Did Aaron pull down his 2.2LR that he built? didn't have have the ceramic coatings on the pistons? (the light brown stuff).
Old Jun 16, 2010 | 02:04 PM
  #287
Svendiesel's Avatar
Ya I probably hit up the forums every hour or so for like 5 or 10 mins at a time, I work at a wine shop and if its quiet and I have some down time Im able to jump on for a bit. Rock though...his F5 key must have a hole in it
Old Jun 16, 2010 | 02:36 PM
  #288
RockmanX's Avatar
Just like superman said.
"Im always around" thats what happens when your trying to absorb alot of information to gain waaaaaaaaaaaaaaay more knowledge i tell you what at night time i answer alot of questions for sure but i dont mind i remember when i got my evo and needed help first person to help me was MELLON TUNING and he continued to assist me free of charge as he is just cool like that
gSx
Jun 4, 2014 07:07 AM
EvolutionIXMR06
Apr 12, 2014 11:19 AM
David Buschur
261
Mar 5, 2011 08:03 PM
David Buschur
Apr 26, 2010 05:22 PM
feldguy
46
Oct 8, 2007 08:54 AM
