BR, 2.4, high hp/high rpm build?
4g64 2.4L is usually built with 150 mm rods for a r/s ratio of 1.5
4g64 2.4 LR is usually built with 156 mm rods, for a r/s ratio of 1.56 (1.6) although custom rods are also available in 159 mm and 162 mm improving the r/s ratio.
Plenty of 2.4s out there running fine no issues without them. again not needed. another safety insurance yes but not required.
Regarding the squirters. It's the difference between having a good engine and a great engine. I mean, If you're already in there, take the extra step. Don't half *** it.
edit* However, I do understand, if customers are not demanding it and accept what is offered at the current price point, why bother.
Why would you NOT put oil squirters on a high powered, turbo'd car ? I guess the same could be said for an oil cooler...
If you are going to build a killer motor, why would you not add a simple think like oil squirters for a few more hundred dollars ??? Can a street motor last without them - probably, but is it worth it ???.....
