BR, 2.4, high hp/high rpm build?
The engine/option is ready now.
This first 2.4 is done and built. The head from Rogue's car is being checked/cleaned now. I am expecting the car to be running and finished next week. We just pulled it in the shop yesterday.
I'm expecting some BIG torque numbers out of this car. We will see.
The price doesn't include the head. The stock EVO head needs some work done to it to use with the 2.1 or 2.4. You can send it in to us and if NOTHING else is wrong with the head we can do the work for about $100.
Also, update. The long block/engine is back together for Rogue's car and I'm guessing will be running in the next day or two.
[QUOTE=davidbuschur;7858732]The price doesn't include the head. The stock EVO head needs some work done to it to use with the 2.1 or 2.4. You can send it in to us and if NOTHING else is wrong with the head we can do the work for about $100.
[B]Also, update. The long block/engine is back together for Rogue's car and I'm guessing will be running in the next day or two[B] [QUOTE]
cant wait!
cant wait!
just a question,what kind of failures do people see from reving a 2.4 or is it just not a good idea on paper?just curious to know because we rev 2.4 k series motor with 99mm cranks to
10k without a problem making about a 1000hp.motor was taking apart and everything looked excellent.i know this is not an evo motor but i think they are similar in concept.this is on a stock honda crank also.thanks ahead
I'm eager to see the results of this build!
