BR, 2.4, high hp/high rpm build?
Old Jan 6, 2010 | 11:52 AM
  #151
JC evo1's Avatar
Originally Posted by nos51
just a question,what kind of failures do people see from reving a 2.4 or is it just not a good idea on paper?j
I know of a 2.4 that revs over 9K alot and has been doing so for years without any failures (apparently). I know that if i were building a 2.4 with high rpm in mind i wouldnt be using Manley Turbo Tuff rods, seems like a bad idea to use one of the heaviest rods around.
Old Jan 6, 2010 | 02:05 PM
  #152
nos51's Avatar
Originally Posted by SeanC
It's funny that someone finally mentions a K-series Honda. You're right, there are many people turning 9K plus in these engines with long strokes. I really comes down to how long you want the engine to live. For street cars, this is rarely an issue since you can't drive at WOT or 9000RPM very long or often.
I'm eager to see the results of this build!
yes exactly we have ben doing this for years without issues on kseries/k24 motors.....as far as the life of the motors i dont see them lasting any less than a 2.0 liter k series motor which is more ideal for high rpm....the only thing i would be more conserned about is what david said earlier in the thread that the 4g64 cranks crack under high hp.wonder what kind of cracks....
Old Jan 6, 2010 | 02:10 PM
  #153
nos51's Avatar
lol funny thing is the k24 that im talking about runs those SAME exact rods...with no problem....
Old Jan 6, 2010 | 10:00 PM
  #154
SeanC's Avatar
They probably crack at the radius on the rod journals. A thicker crank, with a larger radius and better material will handle the loads if this is a problem. I know AMS has been using K1 Technolgies billet cranks in their high power builds. Cosworth makes a very nice crank too if you have the money.
Oops, threadjack. Back on topic...
Old Jan 6, 2010 | 10:17 PM
  #155
xRoguex's Avatar
Originally Posted by ROGERV
I think he's running the Fp Red Turbo.
Yup. 80mm FP red
Me too. Should be done and on the rollers tomorrow. But I cant go get it til friday or monday. =( I have to get my fully impacted wisdom teeth surgically removed.. at the age of 25... wtf. So while my cars playin on the dyno.. im going to be doped up on NO2 and an IV drip.
I'll let you know how its doing after a couple thousand miles.
Old Jan 6, 2010 | 10:41 PM
  #156
JohnBradley's Avatar
A bunch of things that i didnt know about K series and a few others:
http://www.8thcivic.com/forums/engin...fo-thread.html
Cliffs- R/s of a K24 is 1.54...I should listen to Groc a little harder in the future.
Old Jan 7, 2010 | 04:24 AM
  #157
nos51's Avatar
yea the only issue we run into with spinning these k series high is the oil pump can cavitate after 9k but that easily resolved by running an s2000 oil pump with an erl kit.however i used to spin my k20 to 10k on the stock oil pump with no issues alot of all motor guys go even higher on the stock pumps.
Old Jan 8, 2010 | 03:45 AM
  #158
Nomad4g63's Avatar
the 2.4 is a great motor but the price that BR has advertised of $5650 is a litte steap. Lets say u get 900-1100 for your block still brings u down to 4750-4550, and thats ALOT more than what a 2.0L build costs, yet from what i hear 2.4L motors are much easier to come by and cheaper to find cores.
Old Jan 8, 2010 | 05:34 AM
  #159
SloRice's Avatar
Your pricing is a bit off.
The $5650 price includes the 2.4L block and the Manley stroker kit (crank, rods, pistons)
The 2.0L price is $3050, but that assumes you have a good 2.0L block and crank core. If you don't, a brand new 2.0L from BR is $5588.
$62 isn't "ALOT more" as you put it for this motor.
  #160
MJ23FE's Avatar
Will this change anything you're currently doing knowing how high the K24's are revving?
-Jalal
Old Jan 8, 2010 | 06:26 AM
  #161
tscompusa2's Avatar
any progress on this? im interested in seeing it.... I know how dsm's perform with 2.4's an evo should be nothing short of that.
Old Jan 8, 2010 | 06:29 AM
  #162
ROGERV's Avatar
https://www.evolutionm.net/forums/ev...ts-inside.html
Old Jan 8, 2010 | 06:44 AM
  #163
tscompusa2's Avatar
Nice thanks I didn't even think to check the dyno category
Old Jan 8, 2010 | 07:32 AM
  #164
nabilsx's Avatar
I check the dyno section but could not see the dyno graph, its totally black.
Old Jan 8, 2010 | 08:29 AM
  #165
twkdcd595's Avatar
I see you only pushed it to 7500 rpm in the other thread with the dyno sheet due to the smaller turbo and tune from what I read in your postings.
Can we expect you put will be putting a turbo on it to properly show it being capable of the 900+hp and 9k rpm you put an emphasis on? Dont mean to sound like a dick but thats the point right... big power and RPM capable. Seems like you would want to make that the priority to test what its purpose built to achieve instead of the FP red/ stock ecu/ etc. build.
