crazy loud noise!!!
Old Nov 17, 2009 | 06:12 PM
  #31
buchnerj's Avatar
Haha, wait you think just patching the hole in the TC is going to fix it? Obviously something inside the housing had to go or stretch in order to actually crack it, unless you hit something that cracked it. I would first check the fluid and see if theres any chunks or metal shavings in there, or if there is any fluid at all in there with a crack in it. Then I would take it and send it into shep and see what he says, chances are a gear went or it threw a chunk of metal and cracked the housing. Patching it will do no good, unless something bounced up and broke it from the outside. Even then I would replace and not patch it, just sounds shoddy to me.
Old Nov 17, 2009 | 06:14 PM
  #32
buchnerj's Avatar
Oh and FWIW, chances are your launch did it in, especially if that is when the problem started. So it is a problem INSIDE the transfer case and the assembly is shot, not just the housing. It needs rebuilt or replaced. If you are going to race and launch it, you need to get it upgraded anyways, it will only last for so long. Yours just decided to take a dump when you did that first launch with the clutch. **** happens.
Old Nov 17, 2009 | 06:39 PM
  #33
yahu's Avatar
^exactly. To people saying "I know others that abused it straight away," of course you did. Recommendation is to break it in while taking it easy. Is it going to absolutely cause an issue if you don't follow recommendations? Would breaking it in properly have not caused this issue? No one really knows. I would still follow recommendations for a new clutch install.
Same thing with anything. Properly turn off your computer or you could suffer data loss. Is it absolutely going to happen? Hell no, I've done it a million times. But, I have also had data loss, so it can happen if you don't follow recommendations.
The cracked t-case "plug" and all will be good sounds fish, OP.
Old Nov 17, 2009 | 08:55 PM
  #34
digdat's Avatar
Originally Posted by javip1986
All i did was a 5000 rpm launch on the road before the noise got worse.
did you build boost when you launched or was it just rpm rev?
Old Nov 18, 2009 | 09:31 AM
  #35
batdude8's Avatar
Launching on a brand new clutch isnt going to break the clutch, it will cause premature wear, and will most likly glaze the disc/pp. It will however break other drivetrain components...
Old Nov 18, 2009 | 07:39 PM
  #36
BenJ's Avatar
sounds like something in the t-case gave out. By welding the crack, you will not fix the problem.
Old Nov 18, 2009 | 07:45 PM
  #37
06ravenmr's Avatar
dude i hope u figure it out...i have a noise in my car now... i think its the tcase as well. but the noise isnt loud enough yet where im gonna worry about it.. well since u broke ur tcase at lest u know ur clutch is grabbing... thats y they upgrade the casing bolts on the tcase when u send it in.. it just keeps the stuff inside the tcase from expanding!!!
Old Nov 18, 2009 | 07:47 PM
  #38
06ravenmr's Avatar
i doubt if he broke the clutch in this wouldnt happen. lol. it would of just postponed the lifespan of the tcase till after the breakin..
Old Nov 18, 2009 | 07:50 PM
  #39
06ravenmr's Avatar
also i bet ur mechanic didnt refill the tcase and trans properly after he installed it.. ur suppose to run ur car and top off alll the fluids after going for a short drive...
Old Nov 18, 2009 | 10:16 PM
  #40
javip1986's Avatar
Will see what happens. The mechanic is paying for this so.. He thinks the crack was done by his helper when he was taking out the tranny, everytinhg inside looks "fine" suppously. If this doesn't fix the problem he will replace the tcase.
Old Nov 18, 2009 | 10:24 PM
  #41
BenJ's Avatar
well at least it seems like you have an honest mechanic!
Old Nov 19, 2009 | 05:08 AM
  #42
buchnerj's Avatar
Yeah, sounds like a reasonable guy. Good luck, take a picture of the crack and we can probably tell you if the weld will help. Most likely not, but worth a shot. And, you have to ask yourself this question, wonder how long that patch will work? You went in with a brand new transfer case and came out with one that whines and was cracked, are you satisfied with that?
To be honest though, I really think you did the most damage during your launch. If there wasn't a noise and then you dropped it at 5000 rpm and after you heard the whine, or felt vibrations, then you caused it, or at least significantly contributed to it. Good luck.
Old Nov 19, 2009 | 04:26 PM
  #43
javip1986's Avatar
i think i did contribute to the problem, but the noise was very minimal when i left the shop 30 miles later got louder and definately worse when i did my little launch. I think that the crack was there all along but as i was driving most of the fluid was squirted out and causing the noise to get louder. At least my mechanic is a decent guy.
Old Dec 3, 2009 | 03:34 AM
  #44
yahu's Avatar
double-negatives rocking my brain right now. If you read my post I stated that no one really knows what would have happened. Regardless of the break-in period I agree that it sounds like this would have happened at some point.
Good to hear about the honest mechanic and this working out in some form or another. Good luck, OP!
Old Dec 3, 2009 | 03:49 AM
  #45
FX11's Avatar
Make sure your mechanic puts the right fluid in your tcase and tranny. They are both DIFFERENT
15outlanderspor
Outlander Sport
23
Dec 7, 2016 04:07 PM
OG
May 3, 2012 01:55 AM
otter
31
Apr 13, 2012 09:19 PM
damianhindley
Apr 25, 2011 02:17 PM
SLO-EVO
Nov 9, 2010 11:59 AM
