chirping ac belt after replacing old chirping belt with new one
Old Nov 19, 2009 | 02:02 AM
MRfabolous's Avatar
chirping ac belt after replacing old chirping belt with new one (FIXED THANKS GUYS)
hey guys i have a little problem do water pumps make a strange sound when they start to go bad i noticed a chirping sound in ac belt i know this because when i remove the belt the chirping sound goes away. the sound is still there i replaced the belt, idler pully, and tensioner pully, and my car has no ac the the belt only drives the alternator, water pump, idle powersteering pump, and tensioner my car only has 45k on it. what could my problem be guys oh yeah if i spray armor all the the belt a little the chirping sound goes away for a couple hours. please help the car has just been put together from a new built bottom end head the works and every little noise has me worried.
ps i have searched for weeks and i am not having no luck please help fellas
Old Nov 19, 2009 | 03:53 PM
IXmr321's Avatar
Did you not put a new water pump in when you had the block built? I have heard bad water pumps that squeak.
So you're AC compressor isn't hooked up at all? If it is, it may be the pulley on the AC compressor.
Old Nov 19, 2009 | 05:12 PM
EvoRob22's Avatar
You replaced the tensioner or the tensioner pulley? Could be a bad tensioner. Before replacing anything try taking the belt off and cleaning the pulleys and the belt.
Old Nov 19, 2009 | 06:19 PM
barneyb's Avatar
I don't like the idea of spraying any sort of lubricant on belts. The most common cause of squeaking belts is slippage. Armor All may make the sound go away but it may also be adding to the problem.
Old Nov 19, 2009 | 09:21 PM
MRfabolous's Avatar
i was just trying things with the armor all i was only using a very little bit like a very little yes the ac is off the car completely i have the ac delete belt on the car from gates. it is not anew water pump still the stock one it has about 40 k on it. i tried the belt spray it made it way worse. and it is a new belt on the car also. i used a tensioner and a idler pulley froma buddys evo that was running at the time of the switch sound still there.
Old Nov 19, 2009 | 09:38 PM
4RETECH's Avatar
If you sprayed the belt, it's already too late.
Try this, use a wax crayon while the belt is spinning(note ribbed side). Also note: watch your fingers!!!
Note: to be done by a professional grease monkey!!(my disclaimer)
If the sound goes away with the wax, it is the belt.
Then just clean off all of the pulleys with a wire brush and put a new belt on.
Good luck..
Old Nov 20, 2009 | 02:14 AM
yrkesman's Avatar
I'm not familiar with evo engine, but can the pulleys be misaligned? My Ford Cosworth also makes whining noise and I just noticed that my pulleys are misaligned and I'm guesing that is the cause of my noise.
Old Nov 20, 2009 | 09:54 AM
EvoRob22's Avatar
When you inspected pulleys did you see any abnormal wear anywhere? Try using shop solve or brake clean to clean off the pulleys and see if that helps.
Old Nov 21, 2009 | 12:16 AM
MRfabolous's Avatar
i cleaned off all the pulleys today with brake clean i tested them there was no drag on them they spun fine. so should i get a new belt and try cleaning off the pulleys one more time the sound comes and goes now. i also looked at the water pump no leaks and that pully also spins fine. anything else guys i am missing i appreciate your help a lot i really do. let me know what you guys think.
Old Nov 21, 2009 | 03:44 AM
MR. EVO MR's Avatar
old school and used car dealers rub bar soap and it goes away.
Old Nov 22, 2009 | 02:41 PM
MRfabolous's Avatar
thanks guys the wax crayon fixed it. i will get a new belt this week thanks i guess this belt was bad because as soon as installed it squeeked thanks again.
orion4096
35
Jan 25, 2016 03:37 PM
Jehuty
Lancer Troubleshooting
13
Apr 20, 2011 11:57 AM
sdfontanini
Oct 5, 2010 11:23 AM
Dwalk08
Lancer Engine Tech
Jan 30, 2009 07:05 AM
ToMuchBoost
10
Sep 18, 2007 10:22 AM
