blown head with head studs possible?
Old Nov 19, 2009 | 03:34 AM
MR. EVO MR's Avatar
I was just thinking if head studs are installed and car overheats bad will the head still blow, even with head studs?
do head studs stop a blown head?
Old Nov 19, 2009 | 04:16 AM
eTiLiKo's Avatar
Nothing can stop a head to blown if a sever overheat happens
Old Nov 19, 2009 | 04:17 AM
hotrod2448's Avatar
There are no guarantees just because you have upgraded head studs.
Old Nov 19, 2009 | 05:24 AM
Gary@MellonRacing's Avatar
true
Old Nov 19, 2009 | 05:39 AM
buchnerj's Avatar
The upgraded studs might hold it a little longer, but won't save you if the problem was that bad. What happened? How hot did it get?
Old Nov 19, 2009 | 02:09 PM
MR. EVO MR's Avatar
nothing happened now, it was a couple months ago. My head blew because I overheated bad, the needle was up high and I was driving without noticing it
I now have a built engine (lucky me)
Im just thinking what I did wrong or what I could of done to prevent it again.
thanks for the honest responses
Old Nov 19, 2009 | 02:12 PM
tweakdsm's Avatar
tune? too much boost?
Old Nov 19, 2009 | 02:17 PM
EvoRob22's Avatar
I think technically the head bolts should be fine, but I would replace them. I don't like reusing head bolts in the first place.
Old Nov 19, 2009 | 05:52 PM
barneyb's Avatar
I've often thought that the temperature gauge and oil light (or better yet, an oil pressure gauge) should have a loud aural alarm. With the electronics they have these days how hard would that be to do? Still, you'd have the owner who thinks they can drive the 10 miles to home once it goes off.
Old Nov 21, 2009 | 01:12 PM
hotrod2448's Avatar
The best thing you can do is be aware and check your gauges frequently while driving.
Old Nov 21, 2009 | 01:22 PM
4g63smokinall4s's Avatar
This is prolly the best thing you can do.. learned my lesson with my 2g when something kicked up on the road and hit the oil filter asselbly and cause me to drain all my oil going down the highway.. looked down say low pressure pulled over saw the WHOLE side of the car covered in oil and it was too late.. scorned all the crank bearings.... always look at ur guages thats what their there for...
Sheasta
Oct 29, 2015 05:00 PM
EVO 4 life
Oct 26, 2015 08:11 PM
evoboy2006
May 1, 2013 06:53 AM
qlitv
32
Apr 6, 2008 02:01 PM
TampaTurbo
23
Oct 20, 2005 04:44 PM
