Evo 8 Turbo life?
Old Nov 24, 2009 | 08:38 PM
Spac3clown's Avatar
Evo 8 Turbo life?
Anyone know about how many miles the stock evo 8 turbo starts losing power?
I am around 88k miles now.
The turbo pulls well most of the time, however there are times I feel like it makes it spooling noise but isn't doing anything at all.
Old Nov 24, 2009 | 08:40 PM
[I.R.A.]_FBi's Avatar
Checked all of ur charge pipes?
Old Nov 24, 2009 | 08:41 PM
Kracka's Avatar
My guess is that your turbo is fine but you might have a few boost leaks or maybe are in need of new spark plugs.
Old Nov 24, 2009 | 08:58 PM
EvoRob22's Avatar
When a turbo usually goes bad its because the bearing that the wheels spin on gets shot. Keep in mind that bearing is spinning at XXX,XXX RPM's when at full boost. Easy way to check is to take off the intake from the compressor side of the turbo. Grab a hold of the shaft and wiggle it. There should be no shaft play noticeable in the turbo. You may also have a boost leak.
Old Nov 24, 2009 | 09:30 PM
4RETECH's Avatar
check for boost leak.
Mine is still good at over 187,000 Miles.
Old Nov 24, 2009 | 10:01 PM
Spac3clown's Avatar
Looks like I will be checking for boost leaks and the shaft ASAP.
Do you guys know if upgrading to an evo9 turbo would be worth it or just simply buy something after market? I
Old Nov 26, 2009 | 04:02 PM
hokiruu's Avatar
Unless you've been doing something pretty wrong for a long time, like running it at extremely high boost levels with an improperly functioning BOV/DV, not changing your oil, etc. I'd be surprised if your turbo was bad. I'm willing to bet it's a boost leask.
4RETECH, that's impressive and reassuring. Good for you for KISS and running strong at that mileage!
Old Nov 26, 2009 | 04:53 PM
YogSaahoth's Avatar
Veteran: Army
there are numerous options to replace your stock turbo...one thing that is common to them all is a IX turbo to start with, so you will probably want to start there. u can get used IX turbos on here for relatively cheap...i got one a few months ago w/ about 15kmi on it for just over $400. even with just swapping the IX turbo for ur VIII will get u some gains for sure.
Old Nov 26, 2009 | 08:03 PM
Spac3clown's Avatar
After looking under the hood I noticed the stock hose for the UICP had worked its way loose. I still may want to upgrade the turbo so ill keep the helpful reply's in mind. I am trying to baby this thing as much as possible but I am limited to doing much because I don't have a mechanical background.
iTune
Oct 2, 2016 07:56 AM
Master Evo8
Nov 5, 2012 07:00 PM
evo8forme
Oct 14, 2009 07:00 AM
dhonibhai
Jun 15, 2009 11:25 AM
PedroMartinez
14
Mar 14, 2008 08:14 AM
