HTA gt3582 vs 6262 on 2.3 engine
Sorry I was unaware that this discussion was about twin scroll turbos.. My knowledge is only with open scroll and I have graphs to back it up.
If you are not drag racing the car and do not care about making over 700hp the 86 and 6262 are to big for you and the lag trade off isn't worth it.The HTA3582 is capable of making 700hp and making over 300 of it before 4k rpm...
These turbos work best in a single scroll configuration for peak hp, by choking them down with a twin scroll only kills the turbos top end performance in trade for trying to get more low end spool... Why do that to a big turbo, why not just buy the right size snail from the start?
I currently own both turbos, and am selling both of them.. So I have no bias towards either, just speaking cold hard facts...
If this discussion is twin scroll based I will happily see my way out of it.
Its all personal preference and what the driver likes.
I really love when people say twin scroll chokes up top. If setup improperly I agree. But when setup corectly your so far from the truth. This thread is not based off of twin scroll. I stated I have used 5 different turbos on a twin scroll platform. It's my experience with them. My 10.1 was on 100oct 38 psi trapping 141 mph. It's far from choking anywhere. Its also a full 100% street car. On the dyno in 3rd gear at 8700 rpm I am just about finished making power.
Here is what Buschur says for the 86 vs 6262
https://www.evolutionm.net/forums/9691906-post85.html
I did answer this, I think. The 6262 was laggier and made less power. The fitment is also not identical last time I tried so it won't fit on my car and I'm not building a new header try it out.
I wouldn't even consider this turbo, now back between the 82 and 86, Buschur made a great post on this... If your not running 9's with the .82 it makes no sense in going to the 86... Something like that. Trying to find it.
its more peak power not more power. hta86 all day over the 6262. Not sure about the 6266.
How can it not flow less full tilt, the divider in the turbine housing decreases flow through the turbine. Someone do the math and measure the size of the divider, I bet it blocks 5-10% of the inducer's area. TS gives up some top end to gain down low, you can't have your cake and eat it.
maybe your comparing a .82 open to a .82 twin scroll. in that case your correct but you would have to be a dumb *** to not compensate for the divider. a TS 1.06 T4 is like a .82 open scroll housing. i have no issues uptop. my car has proven to me real world results. i know the facts i own the facts and i drive the facts. the only thing i have yet to figure out is how to make my flux capacitor work to make time travel possible. so dont argue with someone who can back it up. im not the greatest driver but my times speak for them self. even though i think they suck.
I would agree a properly designed twin scroll has more HP choking back pressure than a properly designed open scroll. This has been proven over and over but just not made public knowledge on this board. A drag race car doesnt even utilize the beneficial effects of twin scroll. which is better low rpm spool and transient spool. A drag car stays at high rpm from start to finish.
For most users, the divided housings easily show their advantages in efficiency and spool. Some people will doubt or dislike the housings, and there is nothing wrong with it. Happens with everything.
do you even know wtf your talking about???? i have my cake with the sweetest icing and i eat it all day long.
I was reading an old thread on mlr and it reminded me of this post, quote from Geoff at full race;
"Regarding the GT30 and GT35 turbchargers - they are based on the GT28R frame/bearing housing/chra. As a result it uses a very short/narrow turbine wheel. When used on a divided twinscroll housing with a thick divider in the middle of the turbine wheel, this causes reduced flow area at the turbine wheel inlet and is a major reason why the gt turbos are not ideal for twinscroll applications."
Seems to back up what I said. I don't have a TS 35r housing here but Im sure someone cound measure the divider area? Personally I don't think 141mph is impressive at 40psi with a HTA86, the turbo should be capable of alot more. I bet your exhaust backpressure is high, have you measured it? I'm not having a go at you Dan so don't take it that way.
[WTB] 2.3 Stroker pistons 85mm
nikush
Apr 24, 2016 03:20 PM
jameswwt
19
Apr 26, 2011 11:59 AM
