FP Red,or HTA3076???
Old Jan 10, 2010 | 10:44 AM
STWHY?'s Avatar
Ive come to that point where its time to take the next step..Im a welder,and can make my own manifold..But,dont really want to run racegas all the time,or meth..Looking to make around 400-450..And not have to much lag..Which would be a better option on a stock longblock??Thanks..Justin
Old Jan 10, 2010 | 11:04 AM
evoxsi's Avatar
if money is a problem id go with a stock frame turbo since u will save a lot. theres more stockframe choices then just fp if u want the max power the turbo offers i dont think theres enough difference to justify getting a 3076 turbo kit. u will have more lag with the t3 compared to a stock frame turbo. but if u r interested in a 3076 i have a CBRD 330r hybrid with 82ar 4 bolt for sale on the forum. i made 486 on a mustang dyno with pump and meth.
Old Jan 10, 2010 | 11:20 AM
javicracer's Avatar
ill go with the hta man, im running one on my car and that **** feel like my old 35R,
A 2.0 both turbos will spool around the same rpm.
Old Jan 10, 2010 | 11:50 AM
STWHY?'s Avatar
Thats what i was asking???What rpm does it spool???the 30R that is..Thanks..Justin
Old Jan 10, 2010 | 12:50 PM
RockmanX's Avatar
naaa would not get the 30r old tech might as well cop the red. if your worried about spool so much you should really consider the hta green or the bbk full to be honest. Good job deciding not to run meth
Old Jan 10, 2010 | 02:27 PM
Ted B's Avatar
Do not even consider a non-factory type turbo. An FP Green, BBK, or an FP Red (at most) can get you to that power level without sacrificing more spool characteristics than necessary. Going to an HTA3076R with conventional open T3 manifold will absolutely worsen spool characteristics and will not necessarily bring more power to the table.
Old Jan 10, 2010 | 02:30 PM
R/TErnie's Avatar
FP Red.
Old Jan 10, 2010 | 02:58 PM
norcalSRTrida's Avatar
in your case... FP red.
i had the HTA30r and loved it. very fun street turbo for a DD decent hp beast..
i went from HTA30/.63 to a 6262/.63 and had zero regrets tho...
Old Jan 10, 2010 | 05:41 PM
STWHY?'s Avatar
Thanx for all the replies..RT/ernie,im trying to see if i can make that work..Thanks..justin
Old Jan 10, 2010 | 05:47 PM
o-townFLA's Avatar
what are you planning to do with your car... street terror, drag monster, or time attack...
I would consider a stock frame turbo for the street or strip, but would look into ball bearing turbos for the road course realm...
Old Jan 10, 2010 | 05:48 PM
javicracer's Avatar
right now im hitting full boost @ 4K rpm
Old Jan 10, 2010 | 05:59 PM
R/TErnie's Avatar
Here's the stock 9 turbo vs. the 80mm FP red + Magnus v5!
Old Jan 10, 2010 | 06:02 PM
NitrousOxide's Avatar
If ur aim is 400 pump, then BBK full or HTA green is ur best choice (almost stock spool and 400whp on low-reading dyno).. If u'll run on E-85 then u should consider the FP Red which will be laggier than the previous 2 but will give u additional 50whp!!
Old Jan 11, 2010 | 10:06 PM
STWHY?'s Avatar
Nice Ernie..thanks for the dyno chart..thats the type of info i needed..thanks again everyone..justin
atxevoxmr
Dec 7, 2013 10:44 AM
romogst
Aug 22, 2013 06:57 AM
HondaTuner
Jan 12, 2007 09:15 AM
skiracer
74
Oct 26, 2006 05:57 PM
