maximum boost on the 4G63
Old Oct 29, 2003 | 03:56 PM
ItsStockOfficer's Avatar
I definitley agree, just saying whats possible.
Old Oct 29, 2003 | 04:11 PM
Quickshift's Avatar
Stay around 22 psi to be safe , also if you running this much try to get some higher octane fule to help prevent detonation. The highest ive pushed mine was about 21.5 on my greddy boost controller. I would not recommend much higher without doing any other mods.
Old Oct 30, 2003 | 09:02 AM
gonzstarr's Avatar
OK. My brother hit 1.6 bar wich is 23.2 psi with no problems. But now he keeps it at 1.35-1.4 bar wich is 19.5-20.3 psi on 93 octane fuel, now the question is... Is it safe for the engine to hold that much? the ONLY aftermarket parts are RMR intake and Grounding Kit... and of course GFB MBC. and one more thing... The MBC makes a hissing noise, i've determined the hiss comes from the MBC, not the Vaccum lines, Is that normal for the GFB MBC or is it a bad one?
Thanx
Old Oct 30, 2003 | 09:30 AM
RACER-GSX's Avatar
i ran 26psi in my gsx with a S20g. stock bolts, cams, pistons, rods, pins, head, balancer, motor untouched, with over 85,000 miles on her. i had evc 5 boost controler, 255fuel pump, apexi i/c and pipes, apexi s-afc, turbo-xs rfl bov, ported exhaust manifold and intake and exhaust sides on the turbo, ss super dragger exhaust, act 2600 clutch, jun lighten flywheel, ect...
Old Oct 30, 2003 | 10:32 AM
Thanx
MBC almost all have a small bleeder hole.
20 PSI is fine.
Old Oct 30, 2003 | 10:41 AM
perfworks's Avatar
Originally posted by ex-honda
let me rephrase the question. how much boost can the 4G63 motor handle before you have to change the internals?
I know you must be speaking of the stock turbo? because to ask what PSI is not a good clarification concidering CFM is important not boost pressure.
But i will concur that 30 psi sounds reasonable given the strength of the motor in stock form
Old Oct 30, 2003 | 12:11 PM
johnnysixer's Avatar
all I have to say is ...Damn!
Old Oct 30, 2003 | 12:15 PM
RACER-GSX's Avatar
i would have to say that 30 sounds a bit high for any stock motor, however; for the 4g63 it's probably very possible. i myself would be a little hesitant (s/p?) to run that high. what's the highest anyone has run a stock "4g63 MOTOR" reguardless of what mods were done?
Old Oct 30, 2003 | 12:17 PM
28 for me. But the car was making about the same power as it did at 24. I would think that PROPERLY tuned at 28 psi I would have blown something. nevertheless, It can do it. I think its more a function of power rather then boost. 500 whp at 22 or 30 will prolly do the trick, no problem.
Old Oct 30, 2003 | 12:23 PM
RACER-GSX's Avatar
yeah i know what you mean. 26 was hi boost for my car i tryed 28 psi but it felt like it was actually dropping off faster and it started to cut around 7,000 so i just backed it off and kept it at 26.
Old Oct 31, 2003 | 01:36 PM
Sickdriver's Avatar
I've done 1.81 bar before fuel cut
i think that's around 30psi...
..all fine...
Old Oct 31, 2003 | 05:13 PM
your a mathemetician!.
Sean
Sheasta
Oct 29, 2015 04:59 PM
FastMD4G63Drive
14
Sep 30, 2008 07:26 AM
Boost Oman
Aug 12, 2007 07:48 AM
user 8367547
Australian Forum
Jul 31, 2005 03:45 AM
scottsee
Mar 27, 2005 07:42 AM
