Can the balance shafts be removed with motor in car
What's wrong with stubbing/turning down the front shaft, and just leaving the belt off the back? if its not spinning, its not dragging down power from the engine, at that point its just a little bit of extra weight floating around.
Well granted i have a lift and pallet jack, but i dropped my engine out last night with a total time of draing fluids,removal of tcase, axels and all....3hrs it helps to have the right tools and a shop at tropical heat!!
GL with b/s removal man.
I purchased the AMS one and stil had the oil pump fail, when i contacted AMS they said it could have been any of several factors, I was pissed at 1st but they are correct it could have happened from my install or from the T belt being tight, but to claim its less likely to happen with their kit is a crock of BS
Oh and you would be crazy to do it in car. Its a PITA even with a cam bearing installer
I argued that their could be no difference but I was wrong. I think that the difference lies when setting the eccentric pulley. Depending on where the eccentric pulley ends up when you tighten it can affect the tension. Where the pulley gets sets affects where the fulcrum point is, meaning that if the plunger has to be all the way out to tighten the belt it would infact have more leverage on the belt. so the same force at the end of the longer fulcrum arm equals more force applied to the belt
There is a very specific procedure listed in the service manual. I can't remember exactly off the top of my head but there is a special tool that goes into the two holes in that eccentric pulley and with the tensioner on and the pin still in you tq the physical pulley to 30 inch lbs then tighten the bolt that holds it in place. Then you can remove the pin from the tensioner.
4RETECH
11
Apr 10, 2013 10:42 PM
