Rear Diff Options - Power Oversteer Found Here
I dont know at which point having more plates is overkill. As with most things, I would imagine there is a point of diminishing returns past a certain amount. Its sort of like the hand held razors, what are they up to like 5 blades? Pretty soon it wont be a razorblade but rather a hand held strip of a dozen blades.
sorry off topic.
i can't imagine 1,000,000 plates in my diff can be a good thing. kinda like having a GIANT turbo on my car. i can, but why?
The plates in the diff are the same principle as a clutch, the torque holding increases each time you add a plate with the same force applied. I have the 12 plate and it chartered for a couple of weeks then went away, I know it still spins both tires but ive been thinking about upgrading to a carbonetic 1.5 rear diff so I can still have some lock up for turn in off throttle.
I think this is where the benefit of AYC comes into play - totally open at braking/very initial turn in, then starts locking up/sending power as you turn the wheel etc.
A 1-way differential will provide its limiting action in only one direction. When torque is applied in the opposite direction it behaves like an open differential. In the case of a FWD car it is argued to be safer than a 2-way differential.[6] The argument is if there is no additional coupling on overrun, i.e. a 1-way LSD as soon as the driver lifts the throttle, the LSD unlocks and behaves somewhat like a conventional open differential. This is also the best for FWD cars, as it allows the car to turn in on throttle release, instead of ploughing forward.[6]
A 1.5-way differential refers to one where the forward and reverse limiting torques, Trq d_fwd, d_rev , are different but neither is zero as in the case of the 1-way LSD. This type of differential is common in racing cars where a strong limiting torque can aid stability under engine braking.
A 2-way differential will have the same limiting torque Trq d in both the forward and reverse directions. This means the differential will provide some level of limiting under engine braking.
Ordered the Weir 12-plate, was $200 shipped. Will be running it in my OEM diff with Diaqueen to keep it quiet. On my track tune I expect to run about 450 whp, on my daily driven street tune I will be running roughly 500 whp. Can't wait to see the difference in oversteer and rotation.
wow. $200 shipped..can't beat that. install is easy - I recently took a spare diff apart to rearrange the plates. super easy. I did forget to mark the ring gear's position, though, when I took everything apart....hopefully it's right.
figured id throw this here instead of a new thread...
in the case of the TRE rear diff, does anyone think the HD side cover is necessary on a road race car? i have never launched my car, and dont plan too, it will never go to the drag strip.
