what injectors should i use on my hta green set up?
I plan on running 25 psi on my hta green. It should run around 400whp, wat injectors would work well on this on a reflash.
Just get 1200s in case you decide to switch to E-85 in the future. If you are sure you will just stick to 93 octane then ~800 should be sufficient, especially if you are only pushing 25 pounds. That is a good amount of boost for pump gas setup, though. There are many E-85 stations in the Pittsburgh area, you should really think about upgrading. It is worth every penny.
Come chat in the Pittsburgh regional forum.
David Buschur
Sep 6, 2015 09:27 PM
