remove stock boost solenoid?
Anyone know if removing the stock boost solenoid on an evo would mess anything up? I have an apexi AVC-R and I was wondering if I should just leave it on or what?
I believe removing it can screw things up with the ECU.
However, the flashing the ECU after removal may take care of the problem.
I just capped the ends of mine off and left it plugged in and all though. I run a Hallman MBC, and I have zero issues.
I have a question!In my car(evo 9) i haven't electronic boost controller,but the manual boost controller i can't to regulate it and i don't know where is it.For example if I regulate the wastegate for 1,8 bar the turbine ECU didn't stop at 1,4(normal bar).Could you help me?
I know this thread is a few year old but cut to the point...
I removed the skinny hose looking thing that restricts you from pushing more psi & now I'm not getting anymore boost cut, is that the boost solenoid & is there any bad things about that? I'm getting my car tuned soon.. Please reply back asap
car hasn't been tuned just straight pipe, bov & apexi intake...
Electrical connector is in, only one hose has been disconnected & has a screw inside so nothing gets through... Feels like its boosting less but drives fine, I want to run my normal stock boost without a tune atm...
wang4u
May 8, 2013 09:19 AM
