Evo 9 mr --> fp black??
Old May 14, 2010 | 04:51 PM
bbyevo8u's Avatar
Originally Posted by buchnerj
hta green @ 30+ psi with ported stuff = blown stock motor. Too much torque, too early in the power band. You are asking to throw a rod if you push 30+ even on e-85 on the stock motor with a quick spooling turbo like the hta green.
+1
Old Nov 14, 2011 | 01:07 PM
Broham's Avatar
pardon the resurrection, but much time has passed and thought I would update. the verdict is I found an fp black for cheap. I am planning on getting injectors, cams, turbo, headstuds and a tune this week. I want to see if i can get 440 or so uncorrected dynojet and around 370 tq on stock block/six speed. Just for highway use to see how it holds up. If it blows, 2.4 and swap my 5 speed from my garage.
Old Nov 25, 2011 | 11:54 AM
10isace's Avatar
Thanks for coming back to this and updating!!! I'm very curious how this works out for you.
I was seriously considering the FP Green, but after reading your thread, I've decided against it. I may try the FP Red or Map EF3. I like the idea of not having too much torque too soon.
Old Nov 25, 2011 | 12:19 PM
laramie_05MR's Avatar
I missed this thread some how. I'm still running my 6spd, stock ACD t-case and diffs with 87k on them. The trans was taken apart to inspect for wear and install a spray bar. The gears/syncros are perfect. Now on to what you want to know.
Daily driven for a month before a rod broke at this level.
FP Black 30-40psi in gears 1-4. Took it like a champ.
Gears 5-6: seem to hold just fine at part throttle
I wouldn't worry to much about 4xxhp just keep the TQ under 400 for the rods/gears. Once I find the time to assemble the new block I'll find how much the trans can take at the Texas Mile again.
Old Jan 21, 2012 | 02:22 PM
kikeixmr1982's Avatar
how hard had u got on it though? cuz im getting the new Fp black ball bering ,im stock tranny and TC's ,im planning take to the track to see how it does ,but i hope it dont **** on me....lol
Old Jan 21, 2012 | 02:35 PM
MR. EVO MR's Avatar
Stock tranny here I ran the black and meth in my 05 MR. Was pushing 542whp n 45Xwtq
Now I'm running more wtq 490wtq but less whp on my stock mr tranny.
Depends how rough you get, before I was running stock clutch on fpred too.
Old Jan 21, 2012 | 02:58 PM
I launched it a few times but I use my car for standing mile. My trans/TC was stock. I have the MFactory 4.00FD, custom spray bar, electric pump and cooler now but I have left the TC alone. Everything held just under 600 before I broke a rod. We shall see what it holds soon. It should be ready for the October Texas Mile.
Old Jan 21, 2012 | 03:05 PM
sparky's Avatar
For reaching your stated goal of 425 WHP on 93, I would do the Black. The Green isn't gonna give you 425 WHP on 93. The Red probably won't either on your limited mods, especially on a stock IC.
There are a lot of pump gas dyno charts on the Dyno Tuning and Results subforum. I would do some studying on there if I were you.
It sounds like you want relatively high HP while keeping midrange torque levels down so as to preserve your present drivetrain. In that case I would stay away from the HTA Green as it is a torque producing monster and high torque is what's gonna do in your drivetrain.
The Black will give you the highest HP while keeping torque lower than the other two turbos. It can get you to your 425+ target on 93 while the other two just can't.
Old Jan 21, 2012 | 05:11 PM
icmanevo's Avatar
No one really mentioned a bbk full. I guess thats a little small for 450 on 93?
Old Jan 26, 2012 | 11:56 AM
Broham's Avatar
The verdict is in and the numbers are 436/387 on pump 93@ 28 lbs.
So far I have driven this setup for 2000 m iles daily with plenty of aggressive driving thrown in and 7.5k pulls. The car runs outstanding so far and I'm on act clutch and stock 6 speed trans.
I did however go with s2s and a toxicfab man along with map ss02 and id1000 injectors. The spoolinup cop helped as well with driveability.
I have a ported Cbrown intake manifold waiting and will upgrade t/b along to a full 3" catback and dump for max optimization.
eisnikesb
Dec 7, 2016 08:46 AM
chris the man
May 13, 2013 09:37 PM
Evo3573
108
Mar 2, 2012 04:47 AM
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
ball7068
126
Aug 3, 2008 04:48 AM
