Serious Backfiring
Old Feb 28, 2010 | 09:56 PM
3gEclipseTurbo's Avatar
Originally Posted by vboy425
list your mods
said no mods.
Old Mar 1, 2010 | 06:16 AM
Racco's Avatar
Originally Posted by 3gEclipseTurbo
said no mods.
Yeah..car is stock.
Old Mar 3, 2010 | 06:09 AM
Falcon350z's Avatar
Definitely check the timing next.
If that looks good, pull the valve cover and check to make sure the head is in order. I was hunting down a really bad misfire about 3 years ago, and it ended up being a missing rocker arm for the #2 exhaust valve (I got the car used, God help me).
My symptoms were different than yours (it only broke up over 5.5k) but if it isn't the timing, then I'd look in the head next.
Are there any other symptoms that might be clues (even if you think they're unrelated)?
Old Mar 3, 2010 | 09:08 AM
Racco's Avatar
Well here's the update, I tested the spark plug wires and there was no spark coming from cyl 3. So I replaced the wires hoping that was the issue but it wasnt. After installing the wires there was definitely a spark but car still backfiring & engine light remains on.
I will look into the timing, but how typical is it to jump while in normal driving conditions? Any clue..
Old Mar 5, 2010 | 11:19 AM
Falcon350z's Avatar
It's not typical. But with the back-firing that you've had, it makes it more suspect.
I'm out of ideas on this one; as long as you've confirmed you've got both spark AND fuel going into the cylinder, then I'd check the timing. After that... take it to a good mechanic I guess?
Old Mar 6, 2010 | 11:59 AM
Racco's Avatar
That's exactly what I did, it turns out that the fuel solenoid that controls all four fuel injectors was out (rare).
He replaced it and the car is running like a dream! What a frustrating experience!!
Thanks for all of your inputs.
Old Mar 6, 2010 | 12:11 PM
R/TErnie's Avatar
Fuel pump relay?
Old Mar 7, 2010 | 11:57 AM
Falcon350z's Avatar
Holy ***** - well, glad you got it fixed!
Old Mar 29, 2010 | 03:16 PM
mikesevo1117's Avatar
im having the same problem
hey i am having the same problem sometimes its intermitant and other times its a dead miss on cylinder 3, my evo is modded with bolt ons and a ecu flash from mellon, im a mechanic and tryin to fix this, you said it was the solenoid that controls the injectors? do you mean the fuel pressure regulator fixed your car rocco? thanks
Old Mar 29, 2010 | 03:19 PM
hey what do you mean the solenoid that controls the injectors? the fuel pressure regulator?
Mackman
Apr 19, 2017 08:04 PM
BoostinBird
May 6, 2010 06:41 PM
italianevo88
15
Oct 2, 2009 02:16 PM
Vibrant
Aug 12, 2008 03:40 PM
GOTMEALANCER
Lancer Troubleshooting
Jul 4, 2006 04:58 AM
