Flashing CEL, No code?
Old Mar 1, 2010 | 04:28 PM
Turbo01s2k's Avatar
Hey guys. Not 100% sure if this is the right forum, but it has to do with my engine and drivetrain so i figured it would be ok lol. Feel free to move it if need-be.
Anyways. On Sunday i finished my Trans and clutch swap. I filled all my fluids, bled my ACD, everything went smooth. I started the car, started up fine, runs the same...but i have a flashing check engine light. So i kinda worried, started to look into things. Cant find ANYTHING. Nothing is unplugged, everything is put back together the exact same as before. I decided to drive the car around the little loop, just to see if it would turn off. Nothing, still flashes. Today i had a buddy bring a code reader over, and its still flashing...but not throwing any codes at all. Its all clear. What is going on? The light will flash with the car running, with the car set to "on", and all other times that the guage cluster is lit up.
Any help?
Old Mar 1, 2010 | 07:09 PM
barneyb's Avatar
This is a new one on me. I am not aware of any circumstance when the SES should flash. It is either on or off.
You might try doing something that induces a code and then check to see if it is saved. Probably, the next step (if you care) is the swapping the ECU. I say if you care because having a car with no SES that runs okay is not really a problem according to me.
Old Mar 1, 2010 | 07:39 PM
Turbo01s2k's Avatar
I talked to a few people, and a few tuners and all of them have NEVER heard of an issue with a check engine light flashing steadily like this. Im gonna disconnect my battery tommorow and reset it all...see if that gets rid of it.
Old Mar 1, 2010 | 07:48 PM
Brembo350z's Avatar
Sounds like the check engine light flashing from knock. Do you have the mod in your tune that makes the cel flash when knock is detected? It may be phantom knock from the clutch if it's a twin disc
Old Mar 1, 2010 | 07:54 PM
Turbo01s2k's Avatar
It is a twin disk. Its not that kind of flash though. I do have my ECU setup to flash with knock, and i have had it flash on me before, and its a quick, on/off flash, sometimes 2-3 times, overlapped. This is a steady "blink, blink, blick" while the car isnt even running...
Old Jan 5, 2012 | 08:45 AM
Buddlight's Avatar
Ever figure this out? We are currently having a cold snap here in AK and I'm having trouble starting my car. When I turn the key to ACC my CEL just flashes at me.
Old Jan 5, 2012 | 09:47 AM
llDemonll's Avatar
Get a code reader and see what it says
Old Apr 28, 2012 | 08:46 PM
Howulikemyevo's Avatar
Mine is different, it flask quick when I drive first n second gear. It flash slowly when I full boost on 3rd n 4th gear. Anyone know what is the quick flash is? I know the slow flash mean knocking. Please let me know. Flashing only occur when I step on the gas,not when park...
senate6268
Lancer Engine Management / Tuning Forums
703
Dec 5, 2022 02:44 AM
sebass007
Lancer How Tos / Installations
40
Dec 28, 2020 08:20 AM
darkknightsw20
Jul 8, 2017 01:28 PM
BrandonIX
Dec 7, 2016 02:34 PM
sonicrx
Mar 27, 2012 06:15 PM
