Done a few timing belts on DSMs, how much more difficult on an Evo IX?
Old Mar 2, 2010 | 09:28 AM
92gsxbaltimore's Avatar
Title pretty much says it all...
Old Mar 2, 2010 | 09:35 AM
Force-Fed Performance's Avatar
if you have done them on DSM's you will be fine on evos
Old Mar 2, 2010 | 09:37 AM
jid2's Avatar
Almost the same.
Old Mar 2, 2010 | 09:43 AM
I'm assuming the only main differences are the clearances between the wheel well might be different, and the MIVEC cam needs to be set in the correct timing. Also, can you still use the same tension tool (battery hold down bolt with extra threads)?
Old Mar 2, 2010 | 09:56 AM
Steve93Talon's Avatar
Like you said, a little less room down there compared to a DSM (although if you've worked on a 2G you're already used to working in tight spaces). The MIVEC cam gear "floats" when there's no oil pressure so just line it up like normal.
I've seen people snap the modified battery hold-down bolts in there, be careful. I always use the correct service tool, which is hardened. If you're using that tool, I'm assuming you are re-using the hydraulic tensioner and not re-tensioning anything? I take the time to do it right, personally.
The EVO cam gear timing marks are also on the valve cover, unlike a DSM where you point the notches on the gears toward each other.
Old Mar 3, 2010 | 10:52 AM
barneyb's Avatar
The Evo has a lot more working room than a 1G DSM. The timing cover comes off no problem and the water pump, if replacing it, is in the clear. You do have to pull some things that are different like the power steering pump and bracket (maybe you can skip the bracket if not replacing the proximal pulley). You will also have to drop the engine some to get one of the accessory belt idlers off.
The big difference I noticed is the way the cams want to move on an Evo. On the DSM one cam would move a little. On an Evo they both want to move a lot and with power. This can cause the belt to jump at the crank sprocket while you are messing with the tension. Someone posted a picture of a little plastic block that you stick in between the two cam sprockets, locking them in place, before removing the belt. I want one of those. I also saw a picture where someone had a box end on each of the cam sprocket bolts and a third wrench was used to hold the other two wrenches (and hence the cams) in place. So, a little ingenuity is required here.
Old Mar 3, 2010 | 10:57 AM
SpoolinUp's Avatar
Silver Sponsor
http://www.jayracing.com/index.php?m...roducts_id=213
This thing is priceless IMO. I bought the whole tool kit and it has held up to countless installs.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
barneyb's Avatar
Thanks so much. I gotta order this.
Old Mar 3, 2010 | 01:57 PM
turbotalawd's Avatar
I usually use two black clips (you know the ones from ur office thats used to hold paper togeter) to hold the timing belt on both cam sprockets while they are aligned. Worked for all of my timing belts that ive done.
Old Mar 3, 2010 | 02:22 PM
MR:PartyPete's Avatar
Ams makes or has both a cam alignment tool and tensioner tool. You shouldn't have a problem, experince is the best tool to have.
Old Mar 4, 2010 | 10:31 AM
Steve_P's Avatar
here's the cheap way on my Talon. DO NOT use the battery bolt on the tensioner. I tried it on my first TB change and it stripped on the first use and I almost couldn't get it out. Spend $5 and buy a piece of hardened allthread at McMaster.com
Old Mar 4, 2010 | 12:36 PM
Fourced4cyl's Avatar
I just kept the service manual handy and start from the bottom and work your way up the front of the motor. If you have aftermarket cam gears some of those small bar clamps work well in place of the binder clips. Nice tip on the wrenches and zip ties.
genelee112601
For Sale - Wheels / Tires
Jan 10, 2012 10:48 PM
turboked
Feb 12, 2008 02:02 PM
LoCo4
10
Feb 10, 2007 12:17 PM
fletch
Jul 5, 2005 07:34 AM
The Emperor
14
Jul 18, 2004 01:22 PM
