View Poll Results: What is the best choice for turbo+camshafts for better 3-6k rpm range on 2.3L?
evo9 turbo+stock cams
15.38%
20g turbo+stock cams
15.38%
20g turbo+272 cams
23.08%
FP black turbo+272 cams
46.15%
Voters: 13. You may not vote on this poll
The right config
Old Mar 7, 2010 | 03:37 PM
evodom1's Avatar
The right config
Hello everybody!
Just have finished my 2.3L (evo9) engine build and now try to find the right turbo+camshafts for it.
What I do want:
1 - Lower and faster than stock spool and punch
2 - As much as possible power and torque in 3-6k rpm range (I do not need anything higher than 7k at all).
Please suggest the best choice from the list (or add if I missed some ideas):
1. evo9turbo + stock cams + 42(?) restrictor + stock 02 + stock cat back + aftermarket downpipe/test pipe
2. tomei turbo (or green ar any other 20G) + stock cams + aftermarket 02/downpipe/test pipe + possibly 2.5 aftermarket cat back
3. = 2 + coss m2 cams, but I doubt if it reasonable
4. FP black turbo + coss m2 cams + aftermarket 02/downpipe/test pipe + 3.0 aftermarket cat back
The car has also some more mods like blitz sonic air filter, VW solenoid, 3.0 aftermarket IC (stock IC pipes), the head is ported with stock valves, the ported ex. manifold, compression ratio is 9.2/1.
2 types of fuel going to use - 93 gas for normal driving and e95 for some events.
Thanks for help
Dmitry
Old Mar 7, 2010 | 03:46 PM
evodom1's Avatar
BTW my personal choice is 1, thought now I have both 20g and stock turbo, both cossw m2 and stock cams.
Old Mar 7, 2010 | 03:48 PM
evodom1's Avatar
And what I have already found - few mods that kills spool:
1 - aftermarket o2 - improves topend and smoths the punch
2 - larger IC pipes
3 - larger IC
4 - 3.5 (or 3.0) vs 2.5 (or stock) catback - also moves the power to higher rpm
5 - aftermarket ex. manifols moves the power to higher rpm
Old Mar 7, 2010 | 03:49 PM
alpinsky's Avatar
Practice - criterion of truth.
Should try all available options.
Old Mar 7, 2010 | 06:49 PM
scheides's Avatar
EvoM Moderator
Your question is *way* vague, but if you want better than stock spool on an IX, go with FP 4R cams. You can have 25+psi by 3000rpm even on a 2.0L. If you want the most bottom-end possible, stick with the stock turbo. If you really want the most powerband possible, I say go with the BBK Full, and here's a perfect example:
https://www.evolutionm.net/forums/ev...l-vs-2-3l.html
FP 4R + BBK Full IMHO is your best choice. Any chance you put some higher-than-stock compression pistons in that motor? That'll help down low too
Old Mar 7, 2010 | 07:26 PM
KidEvo's Avatar
I'd recommend an HTA Green with Kelford 264/260s for the powerband you're going for.
Old Mar 8, 2010 | 03:44 AM
evodom1's Avatar
Any 20g turbo moves useful range at least 500rpm higher(Green, Tomei etc) or even 1k rpm (red, black). I want more than stock torgue and hp but in stock rpm range That is why I build 2.3, that is why I increased compression ration from stock 8.8 to current 9.2.
Old Mar 8, 2010 | 03:47 AM
evodom1's Avatar
I even think about to install restrictor in order to have more middle range torgue. May be I should go fo these cams?
http://www.camshaftshop.com/home?pag...category_id=89
The 4-TX258 camshaft is specifically designed for use in restrictor plate rally car engines. The low duration, high lift intake lobe design and long duration exhaust are a proven combination for this application.
Old Mar 8, 2010 | 11:07 AM
evodom1's Avatar
Does anybody have experience of restrictor instal ?
Welcome2GoodBur
Feb 13, 2017 12:04 PM
bboy_RES
Jul 23, 2012 11:20 AM
geminibby
West Region
17
Dec 3, 2010 10:42 AM
big block ix
Jan 31, 2010 09:59 PM
big block ix
Feb 20, 2009 01:21 PM
