how do you set the cams to TDC?
Old Mar 24, 2010 | 06:30 PM
moevo9's Avatar
I am changing the cams out and the timing belt and i was wondering how do you get the cams to TDC before you start taking everything apart?
Old Mar 24, 2010 | 06:54 PM
compscibOi's Avatar
The stock cam gears have white notches toward the outside of the gear. One set of marks should align and point toward each other when the engine is at TDC.
Old Mar 24, 2010 | 06:56 PM
sharkm87's Avatar
should line up with the indentations on the valve cover
Old Mar 24, 2010 | 07:01 PM
compscibOi's Avatar
You can see the white marks in this pic:
Point them up, cylinder #1 should be TDC I believe. Zip tie those suckers down good and don't rotate the crank mkay?
Old Mar 24, 2010 | 07:09 PM
BoostWhore's Avatar
Check out www.evomoto.com , theres a cam timing write up on there. Take out your plugs when rotating the crank pulley to get the engine at tdc, it will make it spin easier. Also always rotate the engine by hand a couple times after putting it back together to double check your timing.
Old Mar 24, 2010 | 07:10 PM
Evoryder's Avatar
rotate the motor by hand until the mark on the cam gears and the mark on the valve cover match up. Check the evomoto how to when installing cams.
Old Mar 24, 2010 | 07:14 PM
moevo9's Avatar
how can you get you cams to TDC if you cant start the car? I will check tomorrow how far they are off but i have the turbo, exhaust mani, and intake mani off the car so i wont be able to start it. Do i have to just rotate the crank shaft untill its at TDC? Thanks for the help.
Old Mar 24, 2010 | 07:29 PM
compscibOi's Avatar
There should be a crank bolt inside the the passenger side wheel well. Turn the passenger side wheel all the way to the right to gain access to it. Put car in neutral, raise the car up with a jack. Turn it clockwise slowly until aligned.
Old Mar 24, 2010 | 07:39 PM
Evoryder's Avatar
read post# 6 and go to http://www.evomoto.com/tech_articles..._article_id=18
Old Apr 27, 2010 | 11:23 AM
kaj's Avatar
kaj
Originally Posted by Evoryder
read the ENTIRE how-to at least TWICE. the instructions are somewhat out of order and repeat themselves. for instance:
step 9 says:
Now it's time to remove the cam bearing caps. Like head bolts, these need to be loosened in stages, beginning on the outside caps and criss-crossing your way to the middle. Repeat the criss-cross pattern blah blah blah
then step 10 says:
Before we get to removing the cam bearing caps, there are a few things you should take note of about them. blah blah
as you can see, if you follow it step by step, you will run into some SERIOUS problems. oh... and the pictures do not match up with the instructions they are posted with. i think someone made a compilation of multiple how-tos and forgot to edit and check to be sure it's in the right order.
very difficult-to-read how-to.
Old Apr 27, 2010 | 11:53 AM
black95tt's Avatar
Based on the questions you are asking I'm guessing it's best for you to take it to someone that knows what they are doing. If you screw this up you are looking at major damage. Just something to consider.
Old Apr 27, 2010 | 07:06 PM
Hi Im Vinh's Avatar
Just got done doing a boost-leak test today and bringing my cams to TDC was ez for doing it the first time. It's as simple as :
1. Take off cam gear cover
2. Remove passenger side wheel
3. Remove the rubber grommet on the inner fender lining wall
4. Grab a 22mm and turn the bolt till the white markings on the cam gear lineup with the lines on the valve , as pictured in post#4
Ferp
Jul 20, 2017 02:48 PM
EVO8STI
May 27, 2011 07:31 PM
kansaslancer02
Lancer Troubleshooting
Apr 10, 2008 03:52 PM
Johnboy1065
Mar 17, 2008 10:57 AM
Johnboy1065
22
Sep 17, 2005 12:36 PM
