MT-90 safe for my JDM EVO?
Old Nov 5, 2003 | 07:47 PM
raywong's Avatar
MT-90 save for my JDM EVO?
I understand that the JDM EVO 7 and USDM EVO 8 share the same 5-sp tranny, so I guess it is save to use MT-90?
How about the transfer case, front/rear differential? Are they different because of the ACD/AYC? Is it save to use Redline GL-5 75w90?
Old Nov 5, 2003 | 08:09 PM
Fourdoor's Avatar
Re: MT-90 save for my JDM EVO?
Direct from the Service manual.... you need to check if Redline has a GL-4 for the Tranny.
LUBRICANT
ITEM SPECIFIED LUBRICANTS QUANTITY
Transaxle oil dm3 (qt) Gear oil API classification GL-4 SAE
75W-85W or 75W-90
2.8 (2.9)
Transfer oil dm3 (qt) Hypoid gear oil API classification GL-5
SAE90
0.55 (0.58)
Rear differential gear oil Hypoid gear oil MITSUBISHI Genuine Gear
Oil Part No.8149630EX or equivalent
0.55 dm3 (0.58 qt)
Keith
Old Nov 5, 2003 | 08:15 PM
raywong's Avatar
So, is my transfer and diff the same as USDM? Many USDM owners have good result from Redline oils.
Old Nov 5, 2003 | 09:30 PM
timzcat's Avatar
Call Redline, they are probably the only ones who can answer the ACD AYC question.
As for the MT90, I don't see any reason you can't use it in the trans.
Old Nov 5, 2003 | 11:50 PM
Karash's Avatar
MT90 is GL-4...so you are solid.
Old Nov 6, 2003 | 12:24 AM
raywong's Avatar
can I use the GL-5 75w90 for the front/rear diff. and the transfercase?
Old Nov 6, 2003 | 03:24 AM
jemm's Avatar
Raywong : For the jdm/uk Evo with active diffs, its the same spec fluid as the US viscous diffs. i.e.
Transmission : Gl-4 75W90 (E.G. Redline mt-90) = 2.8L
Transfer case (ACD+FRONT DIFF) : gl-5 (e.g. Redline 75w90 or Amsoil 2000 75w90) = 0.6 L
Rear Diff pinion gear compartment : gl-5 (Redline 75w90 or Amsoil 2000 75w90) = 0.55L
AYC
Rear Diff AYC clutch plate compartment : Mitsubishi Diaqueen ATF-spIII or AMSOIL ATF(made to replace atf-spIII) =0.7L
Hydraulic system (bottle in boot) : Mitsubishi Diaqueen ATF-spIII or AMSOIL ATF.
"AYC Fluid" is being phased out and has been replaced by atf-spIII.
p.s. If its an Evo8, then remember the SAYC takes less fluid (.55l) than the older designs.... its easy to overfill!
Do you have a 7 or a 8?
Old Nov 6, 2003 | 07:11 AM
hostile's Avatar
You should tryout the redline shockproof for your transfer case.
It is a heavy duty gear oil.
Old Nov 6, 2003 | 08:50 AM
raywong's Avatar
I have the 7, and thanks for the advice.
I bought 4L of MT90 and 2L of GL5 75w90 after reading some post here. But later I thought the Jdm might need different oil. Some local garage did recommend Shockproof for the diffs. If my diffs are the same as the USDM, I will use the 75w90, since many USDM owners are happy with it.
Old Nov 6, 2003 | 03:35 PM
jemm's Avatar
The fluid requirements are the same. Many acd E7 & E8 owners i the UK & Jamaica use those oils to good effect. There are other choices, but the Redline MT-90 works particularly well with our gearbox. You can't go wrong with either Redline or Amsoil!
I have the Amsoil 2000 in my rear diff (have not gotten around to the transfer & tranny yet) and I have no problems with it.
Old Nov 6, 2003 | 07:59 PM
raywong's Avatar
So the front/rear diff are the same in JDM and USDM.
is the transfercase also the same?
Old Nov 6, 2003 | 08:26 PM
jemm's Avatar
No.
The transfer case which houses the ACD & front diff (most models have the helical lsd), and rear differential (AYC) are different. The 5-speed W5M51 Transmission is the same. They use the same gl4/gl5 lubricants as per the service manual.
Old Nov 6, 2003 | 08:42 PM
raywong's Avatar
I am very confussed. So everything is inside the transfer case including front/rear diff.? How many kind of fulid do I need?
tranny=mt-90
front/rear diff.=GL-5 75w90
AYC=Mitsu AYC fulid
ACD=??
transfer case=??
DR EVO_38
23
Oct 29, 2017 06:56 PM
eddy5201314
12
Dec 24, 2016 04:33 AM
nuggetinu1
Feb 15, 2016 03:16 PM
GsrJake
Dec 1, 2012 12:31 PM
house_of_senate
16
Oct 1, 2009 06:25 PM
