Too much crank case psi! Any ideas?
Subscribe
Apr 26, 2010 | 12:27 AM
more boost = more crank case pressure. Most people running big boost open up the size of the vents, or add another. just do a search.
Reply 0
Apr 26, 2010 | 08:38 AM
Quote: the hose in the front the one that comes connected to the intake from factory actually vents does not suck air, get you a catch can and recirculate the system.
Not correct. At idle there is vacuum in the intake manifold and the PCV valve is open to the valve cover. So, the manifold will pull air out of the crankcase and air in through the vent hose. When boosting the PCV valve closes and the air flow reverses in the vent hose.
Reply 0
Apr 26, 2010 | 12:30 PM
Quote: Not correct. At idle there is vacuum in the intake manifold and the PCV valve is open to the valve cover. So, the manifold will pull air out of the crankcase and air in through the vent hose. When boosting the PCV valve closes and the air flow reverses in the vent hose.
i will agree with you i missrepresented my statement, regarding the vent hose going into the intake and its design.
Reply 0
Apr 29, 2010 | 06:14 AM
That clears things up a bit. Im going to check the pcv tonight and put my catch can back on. Thanks everyone!
Reply 0
Apr 29, 2010 | 11:03 AM
I periodically spray maf cleaner through my pcv valve. Cleans it right up.
Reply 0
Apr 29, 2010 | 11:17 AM
The PCV sometimes fails fairly quickly. I normally replace them about once a year or so. Much cheaper replacing PCV valves than the issues created by excessive crank case pressure.
If it's not the PCV, perhaps you do have a ring problem. I have seen it from new motors (mistakes were made).
Reply 0
Subscribe
