What retainers to run w/ GSC beehive springs?
Old Apr 28, 2010 | 05:35 PM
Saleentones's Avatar
No need for expensive retainers unless going over 9k rpm.. stock is lighter than anything..
Old Apr 28, 2010 | 06:40 PM
_des_'s Avatar
Thats exactly what i thought.
Old Apr 28, 2010 | 07:28 PM
scheides's Avatar
EvoM Moderator
These springs are the best thing to happen to this market since E85! I have them on my car with stock retainers in the stock seats running kelford 272's, on a mildly ported/rebuilt head from MAP using stock valves. I have an economical 'built' head for under $1k that I can rev to 8500 w/o worry. And yes, I have, many many many times!
Old Apr 29, 2010 | 10:52 AM
GregGSC's Avatar
the stock retainer can be used with our beehive springs when using the standard install height. IE keeping the pressure to stand install and not shimming.
The factory retainer is aluminum of some kind and while it is really light I'm not 100% sure of its capacity as far as spring load. FYI we haven't had a failure reported to us on the stock retainer using our beehives out of the 500 or so sets we have running in cars.
Also peak RPM isn't determined by retainer material or strength but by weight, and the stock retainer is just as light as the titanium we sell.
As far as running titanium retainers. we offer the titanium retainers in the 5040 kit including: springs and ti retainers; and also the 5041 kit that offers bases, springs, and a retainer for WFO setups.
Now a couple of reasons to switch to the titanium. for one strength in that you can run higher spring pressures or higher lift cams which bring up spring rates. for 2 the stock retainer will touch the seal above 11.4mm of valve lift causing some issues. and 3rd because its just cool to run titanium any where you can.
If anyone has any questions for me just ask and ill answer them.
Old Apr 29, 2010 | 03:46 PM
_des_'s Avatar
^^^^Very nicely put!
Old Apr 29, 2010 | 04:56 PM
bbyevo8u's Avatar
im running fp beehive spring with oem retainers & kelford 272's, i dont rev past 8k
oem retainers ftw!
ChicagoEvo9
48
Feb 24, 2017 02:21 AM
ohmohm
11
Apr 24, 2014 07:39 PM
jnut24
Northwest Region
14
Oct 11, 2011 08:36 AM
whitepwr
Jul 21, 2010 02:53 PM
Inprogress
Jul 8, 2008 02:43 PM
