Oil Pressure HELP
Old Apr 29, 2010 | 03:48 PM
flymx771's Avatar
Oil Pressure HELP
I have a built 2.3 with about 15,000 miles on it. At idle I usually see 20-22 psi, about 50-60psi on the freeway, and 80psi at redline. I noticed today its only doing 9psi at idle and around 40-45 at freeway speeds. There are no unusual noises or anything else out of the ordinary. I'm thinking my oil pump is about to take a sh** on me. Any advice?
Old Apr 29, 2010 | 04:02 PM
T2Small's Avatar
Oil pressure will change somewhat substantially with heat. You should see lower pressures with hot oil. In fact 9PSI at idle is a little low but not shockingly. If the oil was cold or cool then I would be uncomfortable.
Old Apr 29, 2010 | 04:07 PM
flymx771's Avatar
I was reading that single digits at idle is 'normal', but its the change that worries me.
Old Apr 30, 2010 | 11:14 AM
barneyb's Avatar
I'd watch it for further change, otherwise okay.
Old Apr 30, 2010 | 11:28 AM
thedru13's Avatar
I don't have a built motor just Cams but my oil pressure on a hot day will sit around 4-6...
Old Jul 23, 2010 | 06:52 AM
Yota Eater's Avatar
Veteran: Air Force
On my stock 2.0L, I see ~4 psi at idle after the oil has fully warmed up. This is within the OEM service manual spec of 4.2psi or >. The service manual states 43 psi or > @ 3,500 rpm. I run Amsoil 10W-30.
Old Jul 23, 2010 | 09:52 AM
flymx771's Avatar
Well back in early may the motor let loose unfortunately. I'm hoping to get the car back within the next 2 weeks. Should be a solid build...looking for 450-500whp.
Old Jul 23, 2010 | 10:17 AM
buchnerj's Avatar
Had the same issue with my 2.0, the oil pump died. Sorry to hear about your luck, keep us posted on your build.
Old Jul 23, 2010 | 12:47 PM
Evo8luva's Avatar
Your gauge could be reading low, or maybe if the sensor is remote mounted, that could report "low" pressure. Me personally, I would see this... Built 2.0 w/BS delete, stock oil pump, cold oil (under 100deg F) - 1100rpm 80psi, 3000rpm 110psi, normal (180-210deg F) 1100rpm 35-40psi, 3000rpm ~85psi, 8000rpm ~115psi. Oil temp hot (250-260deg F) about 10psi less across all rpm range. Oil temp and press taken right off the oil filter housing gauges were 5 year old Defi D-gauge. Oil used was valvoline vr1 20w50 non synthetic.
My car before the built motor with 10w30 syn. Would see 20psi at idle and about 95 up top when the oil was warm. I don't remember exact numbers from my stock engine.
Just some of my data, for your info. Keep a close eye on that gauge, if it keeps dropping it may be time for an oil pump or possibly a new motor if you don't catch it in time.
Old Jul 24, 2010 | 04:41 AM
apagan01's Avatar
Many issues can be indictated through this; Thin oils and if you are using a good quality then dont wory. I would start with the oil gauge to make sure you are getting accurate indications, pump might be on its way however usually pumps are good for a while, are you using the same oil filter you always same have used if the filter is clogged it can be in bypass mode and lower your pressure,,,
worst case is engine is on its last leg and you have bigger gaps than ussual internally for example bearings and the pressure drops because of the bigger gaps between the bearings and crank ( But this one is worst case scenario and you would have noticed something like metal shavings or engine differences MAYBE )
Old Aug 7, 2010 | 07:10 AM
Tims2006MR's Avatar
glad to see this post, i just hooked up my gauge and got scared
Jovan Caro
Jan 16, 2017 02:46 PM
veilside prius
Aug 22, 2016 10:43 AM
benIX
Nov 30, 2013 08:13 PM
bdonIX
21
Jun 13, 2013 09:27 PM
binh
Jun 25, 2010 07:29 PM
