clutch and launching problems???
Old May 2, 2010 | 06:00 PM
t8sevo8's Avatar
hi guys i have searched and looked around and cant find nething answering my problems even though im sure its been posted before i cant find it...
so neways my question and problem is im having problems getting into gear when my rpms are high...it actually feels like im hitting a brick walls when trying to go into the next gear...i was told its my clutch and was wondering wat you guys thought...i have the basic simple mods and nothing crazy and am running a ACT stage 4 clutch with the ACT street lite flywheel...i have had it in my car for about a year and a half and the car has always had the problem since i got the car but it had an act clutch in it when i bought it also....any advice on this would be appreciated...
also when im running at the track my car bogs down quite bad coming off the line and i was wondering if maybe this is a clutch problem or possably something else???...ne suggestions on my problems???
Old May 3, 2010 | 01:39 PM
t8sevo8's Avatar
ne1 has ne sugg.?
Old May 3, 2010 | 01:45 PM
ev0lution9's Avatar
well the launching problem i cant tell you but im pretty sure if you search ACT is known to have high rpm lockout issues.
Old May 3, 2010 | 01:49 PM
awddyno's Avatar
same here. ACT = lock out. Go Exedy Twin HD MM022HD
The bogging part, what rpm are you lauching at? are you dumping the clutch?
Old May 3, 2010 | 01:51 PM
ev0lution9's Avatar
yeah only thing i can say about the launching part is your rev limiter is too low or your launching wrong.
Old May 5, 2010 | 01:18 PM
t8sevo8's Avatar
my two step is set at 6k and im slipping the clutch out but over time it is getting harder to slip it just graps and bogs me down...i think i need a new clutch i just wanted to see what yall thought and to make sure it wasnt another issue....
Old May 6, 2010 | 03:16 PM
ACTman's Avatar
In fact lockout issues are common on the EVO with many different kinds of clutches and contrary to what some think, it is not an ACT thing. There are countless threads of all kinds of clutches having shifting issues (including high rpm lockout), but the more famous ones speak of ACT parts. Part of this is the popularity of the brand, but part of this may be my own fault for participating on forums, since it makes conversations longer and more drawn out. Before you know it we have a thread that is many pages long what has a bad title referencing ACT. Most won't even read past page one and that is what urban legends are made of.
I won't try and rehash old conversations, but in general clutches don't operate any differently at high rpm than at low rpm. Sure the disc has more inertia, but that is normal for any clutch and our disc is not significantly different in that regard. However, the engine dynamics at high rpm are quite different. Crankshaft flex and windage in the belhousing are just two examples. The bottom line is that the disc needs more air gap at high rpm than it does at low rpm, regardless of what clutch you use. More air gap is achieved by adjusting the rod at the master cylinder to gain more throw at the release bearing.
Complaints commonly start after the owner has taken his car to the track and suddenly it won't shift like it used to. Folks also don't realize that when they overheat a clutch and the surfaces become uneven, more air gap is needed. This is true no matter what clutch you use. Another contributing factor is that most won't bother to make changes like adjusting the m/c rod until long after they encouter shifting troubles, which puts undo wear on the syncros in the transmission.
I haven't been as active with the EVOm forum as I used to be do to work requirements, but if there are any questions (ACT related or not), don't hesitate to shoot me a PM or email. I would love to help. We are also producing a tech newsletter called "Clutch Chatter" that you can sign up for on our website that is very informative if you are a true gear-head. The next issue is going to the first of a series discussing clutch torque capacity calculations and different design variables. There is so much mis-information floating around, that we want to clear up some of the myths and let people know how clutches really work. Cheers!
thadon84
38
Aug 23, 2016 12:35 PM
aldoevo
Jun 24, 2013 11:04 PM
Pal215
May 17, 2011 10:53 PM
pensport
Sep 7, 2009 09:53 AM
cybertrax
Aug 28, 2009 12:47 PM
