car knocks bad over 23psi.
Old May 15, 2010 | 05:33 PM
Tribal's Avatar
You should get a wideband and see what your AFR's do on WOT......also just like everyone else said its probably your tune.
Old May 15, 2010 | 05:36 PM
evo4life400's Avatar
the afr's were good...and both tuners.....one in particular has done hundreds of evos in CT and New Jersey...the other is more for subies and mustangs and crazy cars but he does evos as well. both of these guys are the top ones in the north east from my research
Old May 15, 2010 | 05:39 PM
Laxman's Avatar
Dude, you need some real data...else you cannot accurately find a correct solution. It could be anything really; phantom knock, bad knock sensor, timing issues, drivetrain harmonics, etc. Get some real data, then start figuring out what you need to do
Old May 15, 2010 | 05:42 PM
ill ask my tuner monday if he can send me the logs....what ones should i get if he will give them to me?
Old May 15, 2010 | 05:44 PM
Macaroni's Avatar
Get the most recent ones and make sure they are full pulls from 2500 to redline.
Old May 15, 2010 | 05:47 PM
okay i will try!!! i wonder if my plugs are toast...how can i tell?
Old May 15, 2010 | 05:50 PM
Macaroni's Avatar
Pull them out and take a pic and post it up...
Old May 15, 2010 | 05:59 PM
im pretty sure i have one step colder plugs but would it be better or worse if i have even colder ones? for some reason i have the ngk's with a heat range of 7 but i could be wrong
Old May 15, 2010 | 06:01 PM
Macaroni's Avatar
I have ran 8es since the day I got my evo... I don't know about everyone else but my plugs have never lasted a year lol... Usually about every 6 months or so I change them.
Old May 15, 2010 | 06:07 PM
i hope that is the case! if it is...i still have to pay another 500 for a tune....that kind of sucks though
Old May 15, 2010 | 06:08 PM
Macaroni's Avatar
Check your plugs and change if needed and see if that helps.
Old May 15, 2010 | 11:47 PM
project_skyline's Avatar
If you got tuned by junior I wouldn't listen to any of these people who are saying get a new tuner. I highly doubt its a timing issue if knock just suddenly onsets at 23 psi.
Buschur and others have reported those cams having phantom/false knock issues. That could be an issue. There are many other causes besides timing and AFR's.
Old May 16, 2010 | 12:56 AM
RSMike's Avatar
have you done a leak test of all your piping/intercooler etc?
Old May 16, 2010 | 08:30 AM
haha thanks....he was one of them...
i did a boost leak test and my throttle body shaft seals were leaking...so i bought works seals and put those in
Old May 16, 2010 | 08:45 AM
sparky's Avatar
Originally Posted by RoadSpike
There have been reports that those cams of yours cause phantom knock issues...
Does anyone have anymore info on the Kelfords with respect to the phantom knock issue?
