car knocks bad over 23psi.
Old May 15, 2010 | 03:08 PM
evo4life400's Avatar
hey guys i have the modifications in my signature and i have been told that my head gasket might be bad or going bad. the car got tuned to about 23psi which is extremely low for what i have. As soon as they crank up the boost the car knocks really bad...my coolant overflow tank level does go down a little but then it stops dropping. i dont have overheating issues but before i remove the whole friggen head....can there be any other problems to cause this?
Old May 15, 2010 | 03:12 PM
Fknfstevo's Avatar
Possibly the tune is too aggressive? What's your timing map look like? What afr's at WOT?
Old May 15, 2010 | 03:18 PM
when he was tuning it everything was good....i dont know what the exact numbers were for AFR's and timing, but as soon as he tried to crank up the boost the car would knock really bad. can it be a bad injector or spark plug? or would he have told me if it was that easy?
Old May 15, 2010 | 03:36 PM
Fknfstevo's Avatar
You would know if it were a bad injector and how old are your plugs? Maybe check the gap and see how they are. Any misfiring issues?
Old May 15, 2010 | 03:39 PM
Fknfstevo's Avatar
That's what I'm thinking... 9/10 times it's due to timing...
Old May 15, 2010 | 03:46 PM
EVO8emUp's Avatar
Who is tuning it, or attempting to?
Old May 15, 2010 | 04:29 PM
plugs are a year old....and no misfiring....im not knowledgeable enough about the timing and all of that stuff to tell you what it was...but what do you mean by aggressive if its only tuned at 23psi?
Old May 15, 2010 | 04:45 PM
RevMoto's Avatar
get yourself a new tuner. I am with everyone else with it most likely being too much timing.
Old May 15, 2010 | 04:49 PM
i used 2 tuners in the past 2 months and both of them are the best ones around.......i dont know what to do and have no idea how to get this fixed! i want to use my setup to its full potential!
Old May 15, 2010 | 05:01 PM
RevMoto's Avatar
Best tuner around? Around here or around you? Don't feel like you are obligated to being tuned by a local. We have the technology to have your car tuned by anyone around the world.
Old May 15, 2010 | 05:06 PM
3gEclipseTurbo's Avatar
What did the shops say they think it is?
Old May 15, 2010 | 05:09 PM
RoadSpike's Avatar
There have been reports that those cams of yours cause phantom knock issues. An expert tuner would be able to verify that with a good look over at your plugs and scope out your chamber for signs of real knock.
You could desensitize your knock sensor with a tune but its honestly a bit dangerous without real confirmation of the knock.
If your knock counts are as high as your making them i'd pull the plugs look for signs of detonation and put a scope in the chamber to inspect the engine.
Good luck man.
Old May 15, 2010 | 05:22 PM
Good luck man.
thanks i appreciate it! i would change the cams if that is the case...i dont feel like it though haha...im sick of putting parts in my car
as far as the tuners...i haven't heard anything bad about either of them and i am confident it is not tuner related
Old May 15, 2010 | 05:24 PM
Macaroni's Avatar
What we mean is that we think your timing is too far advanced and right at it's threshold so when you turn up the boost, it creates more load, air flow, etc and pushes it beyond that threshold.
Old May 15, 2010 | 05:25 PM
Macaroni's Avatar
Good luck man.
I'm not sure but wasn't there a recent thread about the phantom knock issues? I forgot all about that.
