Project Valve Technology Muffler
Old Jun 27, 2010 | 02:56 PM
  #256
n2oiroc's Avatar
stock cammed cars should be easy. generally they arent making enough power to have to worry about backpressure. i have goals of 700+whp. i think stock cams will be a bit of a choke at that level.
Old Jun 27, 2010 | 07:09 PM
  #257
EVO8LTW's Avatar
Originally Posted by BluEVOIX
Actually I dont know if a 7" will fit or not. I cant quite remember how much more space I had with the 6" but maybe cutting a cardboard 7" in diameter and test with it might be able to see if it fits.
But if you think about it, the difference in diameter on each end between 7" and 6" is only 0.5" .
I took a look under my car and did some rough eyeball measurements with a tape measure. I think 7" would probably fit, but it'd be very close to the driveshaft. I'm too chicken to be a pioneer on that, so I just ordered the 6"x14" and a couple of flanges. If it's still not quiet enough (what I expect), then I'll pursue plan B (replacing the rear muffler with a more restrictive one and implementing a cutout in the rear).
Old Jun 27, 2010 | 07:52 PM
  #258
syclone50's Avatar
subscribe
Old Jun 27, 2010 | 09:39 PM
  #259
BluEVOIX's Avatar
You could have also taken a card board. Cut a 7" diameter circle with a 3" diameter center and slip it over the 3" testpipe. In your case you have the bullet which is 4-5" diameter so just make a bigger center in the cardboard. That way you could slide it around and see if it hits anything.
But definitely let us know how it goes with the double magnaflow. Hopefully its able to quiet down the aggressive cam setup you have.
Old Jun 28, 2010 | 09:33 PM
  #260
MattevoVIII's Avatar
perfect flow when open and when closed we got our wonderful crappy stock muffler hehe
Old Jun 28, 2010 | 09:36 PM
  #261
that's what i drew up on paper when i was bored in class, always wondered if anyone has done it
i used QTP twice, i owned their downpipe which i didnt like due to clearance and afr sensor position
second setup i had was 3" dp, 3" test pipe with welded in qtp+ stock cat back, that setup was ok but i still think car didn't have enough back pressure
Old Jun 29, 2010 | 08:14 AM
  #262
Ludikraut's Avatar
That doesn't make sense. Ideally you want zero or negative backpressure from the turbo onward...
l8r)
Old Jun 29, 2010 | 10:52 AM
  #263
idk, car wasn't running that great maybe beacause i still had a stock cat back
or maybe because of the qtp divorce pipe messed up the flow
Old Jun 29, 2010 | 11:39 AM
  #264
3gEclipseTurbo's Avatar
Honestly cutout loose alot of tq, I lost almost 40wtq when I put one on. There only going to help when your 500+whp. Not many people with 500whp+ care about noise haha.
There has to be a replacement muffler for VW with the valve controled by vacumm. Someone go join a VW forum and find a 3" aftermarket one. I did do a little searching around and found some, for $600...................haha.
Old Jun 29, 2010 | 12:09 PM
  #265
SpoolinUp's Avatar
Silver Sponsor
That's exactly my plan Matt, except the cutout will be boost actuated, see a few posts back. I'm massing parts and searching for a stock muffler.
__________________
-Matt- http://www.SpoolinUp.com
"Performance without the Price Tag"
Old Jun 29, 2010 | 05:01 PM
  #266
yeah Matt i really think that setup could be what i'm looking for, but i don't have to go as far as boost actuated hehe
or last option worth a try, magnaflow muffler as a test pipe+ RRE stealth cat-back?
Old Jun 29, 2010 | 05:24 PM
  #267
SpoolinUp's Avatar
Silver Sponsor
I like to over-complicate things.
__________________
Old Jun 29, 2010 | 07:56 PM
  #268
hehe see idk about you guys but i really need a quiet exhaust, i'm the only car on the road at 3am when i'm driving to work
that's why it blows big time
Old Jun 29, 2010 | 09:47 PM
  #269
BluEVOIX's Avatar
For me there are 2 reasons of wanting quiet.
1. For some reason it just sounds like the noise is coming from the front and drones into my ear annoying me to death.
2. Its embarrassing.
Well according to dynomax, I should be receiving the new muffler in a couple days. Also they want the current defective muffler so UPS should be picking that up in the process.
Will update when it arrives.
Old Jun 30, 2010 | 09:38 AM
  #270
i hope this one won't rattle!
that would be the setup to have
