Do axlebacks work?
Old Nov 13, 2003 | 03:45 PM
Dale_K's Avatar
Do axlebacks work?
I just bought a used axleback, you know - the muffler. There were some posts about how they can reduce the boost level by a pound or so. I can understand that adding a boost controller would be a solution but I want to keep my car basically stock. So I have 2 questions:
1. Will a brand name axleback make any extra power on a stock EVO?
2. Same question as above except factor in a Dynoflash. I am scheduled to get one at the end of the month.
Old Nov 13, 2003 | 03:53 PM
Alfriedesq's Avatar
Re: Do axlebacks work?
http://www.pruvenperformance.com/images/aldyno1.JPG
Thats my dyno sheet with and without the pruven axel back
Old Nov 13, 2003 | 07:05 PM
Dale_K's Avatar
Thanks. It turns out that the used one I bought is a Pruven and to show its a small world, the guy I bought it from turns out to be the same guy who gave you so much grief recently.
Looking forward to meeting you on the 29th.
Old Nov 13, 2003 | 07:49 PM
DynoFlash's Avatar
Do you have any boost control on the car at all ????
When you add a axel back you loose boost so the power gains are nominal - but alsways good to make same or slightly more hp at same a lower boost point !
The way to really wake up the axel back is witha HKS EVC V boost controller
ferraro kid went 119 mph with it and Pruven made 340 to the wheels also with the same axel back system
We like to package it with the K & N pannel filter and the HKS EVC V- a nice set up with the Dyno Flash
EDIT: rereading your post I see you want to stay basically stock - if thats the case consider the K & N fillter its a nice 5 whp gain
Old Nov 14, 2003 | 06:22 AM
4-BNGR's Avatar
Like Al said, you're gonna need a boost controller/boost gauge. With my muffler delete pipe I was making 16psi and with the mbc I'm back to 19psi
BTW, you're gonna love the DynoFlash
Old Nov 14, 2003 | 01:24 PM
David Buschur's Avatar
We have both the muffler deletes (3.7 pounds) and the axlebacks (6.4 pounds) instock. Fully stainless and mandrel bent.
Check it out,
David Buschur
www.buschurracing.com
Old Nov 19, 2003 | 08:52 AM
Dale_K's Avatar
I finally got around to installing the used Pruven muffler today. Couldn't notice any power difference with the butt dyno. The sound level was very moderate - almost as quiet as stock at idle and slow cruising. At 75 there you can notice more noise but it's not objectionable because it doesn't resonate/boom in the cabin.
Old Nov 19, 2003 | 09:43 AM
raywong's Avatar
Al, is the K & N a standard drop in? I heard the Ralliart drop in is a good replacement of the original paper filter, have you tried that? I am using a Trust foam filter and thinking of buying a better one.
Old Nov 19, 2003 | 01:34 PM
ex-honda's Avatar
I know people keeps saying that you do loose some boost when you put a bigger exhaust system. I put a RMR cat-back system on my EVO and I have a Defi boost gauge and from what I see on the gauge, I loose only 1 lb. Am I just lucky? I was thinking of getting a MBC but if I am loosing only a pound of boost, why bother. Any way just my $.02
Old Nov 19, 2003 | 05:05 PM
evoracerx's Avatar
My car runs 1.35 bar boost with no boost controler and a JIC cat back exhaust. The catback is the only mod, How does an axel back reduce boost?
Old Nov 19, 2003 | 07:16 PM
DynoFlash's Avatar
K & N is great - - drop in
Old Nov 20, 2003 | 12:33 AM
TRDHarrier's Avatar
yeah...there was a fellow Evo driver that got 7whp from K&N drop-in!!! 7 in a stock Evo!!!!!!! There's a dynosheet somewhere to prove it too.
robban87
Apr 4, 2017 05:40 AM
Blacksheepdj
Dec 2, 2016 08:31 AM
EndlessRed
Oct 25, 2013 06:53 PM
forlorn110
Mar 6, 2011 12:50 PM
NYorkrider
May 11, 2009 08:19 PM
