Anyone running pte 5857 and 6057 (reviews please)
Old Jun 12, 2010 | 01:15 PM
JohnBradley's Avatar
AWD Motorsports ran a 6057 out to 560whp at 31psi on E85. I would look for a bigger turbo unless you are going to run something other than a 2.0 or E85 and more boost. Depending on engine size a 6262 with a .63 A/r still makes good power pretty easily. We have a local 2.3 running around at 546 at 25psi on E85 with pumpgas timing. In otherwords he could be making the same power on 92 octane but is using E85 for the safety factor and reduced EGTs. His is spooled around 4300 or so.
Old Jun 12, 2010 | 05:52 PM
BaDiNfLuEnCe's Avatar
Originally Posted by grim~
out of those turbos the 6262 will get you to 600 hp.
true but so will the black.. Which is why im sticking to it
Old Jun 13, 2010 | 01:41 AM
grim~'s Avatar
you have to push the black alot harder than the 6262 to make 600.
Old Jun 13, 2010 | 01:47 PM
evoboi005's Avatar
i have a 6057bb gsc 2.2l long rod stroker motor stg 2 cams on 23 psi on a dyno dynamics i made 460-390 ish need to get on another dyno ... fun turbo tho i even autocross with it
Old Jun 13, 2010 | 01:55 PM
kmartizdatruth's Avatar
oooooooooook perfect thread lol....i am in the market for a turbo upgrade and i am hearing alot of good things about the 6262...i was wondering aside from the turbo what else would i need to buy to mount this turbo on my evo ix? and about how much would i be looking at? any help would be appreciated
Old Jun 13, 2010 | 01:56 PM
italianevo88's Avatar
i have a 58mm that has some awesome top end, and I only have it at 26psi, its supposed to be awesome at 30psi
Old Jun 13, 2010 | 09:56 PM
EVODreams's Avatar
6262 seem like it is going to be the one for you. Anything less than 600hp, a stock framed turbo is probably your best bet.
Old Jun 19, 2010 | 10:33 AM
supersal's Avatar
I would say cost effective HP:
~550HP PTE5857 T3 .63
~600HP+ PTE6262 T3 .63
~700HP+ HTA3586 T3 .82
ps. a tubular mani for a stock frame turbo + decent O2 dump + intake + FP red/black etc + other odds will end up costing as much as putting together a turbo kit with one of the above turbos... maybe more...
Old Jun 19, 2010 | 10:40 AM
Colt4g63's Avatar
6262 with a .63 A/R will make 700+WHP. The 3586 is good for 10-20 more whp over a 6262 when MAXED out... There VERY close!
Old Jun 19, 2010 | 03:59 PM
1slowassevo's Avatar
Exactly right...they make the same power but the main difference is the 3586 makes a bit more tq at lowet rpms...
Old Jun 19, 2010 | 04:08 PM
EvoLutionized8's Avatar
we will have numbers up in two weeks. Running a 5857 dbb with allt he supporting mods. Gas first (93) then E85 ftw. The 5857 is not for you High hp guys. but it should give you what you need in the mid RPM range with good to great power. I am expecting somewhere in the 550whp/500tq. That may be wishful thinking to some, but i have every supporting mod possible, with some fabbed pieces as well. Stay tuned. Good things are coming for the folks who were in that 50trim family back when.
Old Jun 20, 2010 | 02:03 AM
supersal's Avatar
I think 550-600 for your set-up is very possible - looking forward to the results...
For sure, I know a 6262 is capable of 700HP - I just meant that its not a bad choice for a easy 600HP also...
Old Jun 28, 2010 | 04:41 PM
marck_c's Avatar
PTE 5857 Turbo on 1.6 liter 4G61 Motor. 25 psi. 497hp at 8000 rpm.
Old Jun 29, 2010 | 03:07 PM
bas_evo's Avatar
i can't choose between the 5857 and the 6262.
I'm hoping that the 5857 can reach 550 on 93 oct
Old Jul 30, 2010 | 08:51 PM
I know I'm bringing this back, but did you make a choice? I ran into some money/time issues to getting mine up, running and tune... We are very close. We are going to get it running tomorrow and then hopefully break in...
