many problems....car wants to stall when using clutch in traffic and reverse
Old Jun 30, 2010 | 08:50 PM
evo4life400's Avatar
hey everyone i recently got my car checked out because of the many problems it seemed to have but this one still wont go away.
-first off it doesn't want to make any more power and i know the bbk full has a lot more in it
-i thought the "almost" stalling could be from a vacuum leak but i had it tested and everything was straightened out and it still does it
-we initially thought the head gasket was wearing but once my tuner checked it out he said everything was fine(no overheating, coolant overflow stays the same level.
-the car also makes kind of a popping noise at a cold start and sometimes with warm starts it doesn't want to start and has a hard time turning over
what else could this stalling be from? i heard there is something with the tephra v7 that can cause this maybe?
thanks!
Old Jul 19, 2010 | 12:29 AM
D-VO's Avatar
Looks like its been over two weeks with no reply's; Have you figured out whats going on yet?
If not, there's a couple of things I can think of:
First thing you should do is try to flash the stock ROM back. If that doesn't work, its most likely a mechanical issue. If it was an all of a sudden thing you could need spark plugs, the MAF may be dirty, may have leaky fuel injectors, or skipped timing. Any enigne codes?
Old Jul 19, 2010 | 09:03 AM
20gmr's Avatar
what BOV are you using? may want to run it a bit tighter if its adjustable. I know it shouldn't matter if its recirc' but on my car it made a difference
SunnyC
Apr 14, 2020 05:21 PM
mikebuff35
Oct 3, 2016 04:18 AM
jparz087
Feb 22, 2013 08:41 AM
Evo_IX_Guy
23
Dec 5, 2012 12:19 AM
krisgoodwin84
Lancer Engine Tech
Jul 26, 2012 01:40 PM
