Acree's MAP 2.4L FP Black Build
After talking with Shep, 5th gear synchros will last longer with the Evo IX 5th gear due to a decrease in the RPM drop from 4th to 5th. So I will be going with the Ultimate Ratio Gearset with ISF Treatment. Can't flippin wait...
-Acree
-Acree
Good luck with Shep. KevinD installed the Shep tranny in my car so hopefully it works out for. I'm not knocking Kevin here. I think the rebuild Shep did is junk. I've had a fifth gear grind ever since I bought the car with the tranny in it, and it wasn't even 5 months old. I've tried numerous things to try to fix it, but nothing has worked. Maybe the previous owner beat the hell out the tranny. Who knows, but there's a few threads on here with people having the same issue. Hope it works out for you. I know when I do a rebuild it won't be Shep.
I haven't had an issue with my shep tranny. And having installed dozens of his trannys, they do work excellent. They are not invincible though, and have seen the syncros break/go bad on a few of the really high hp cars.
The alternatives to shep are buschur and tre. I have only dealt with tre once personally and it was months and months before we got the tranny back, and it didn't even work right.
Shep Ultimate Ratio 5-speed transmission is installed and I've put about 300 miles on it. It's butter smooth and I love it. The car will be going back to Evo Dynamics in 3 weeks for some final touches and SD tune on E-85 and 93. Once I get the hail damage fixed, I'll get some pictures up with the final dyno graph.
-Acree
-Acree
I've had a Shep Ultimate ratio tranny for 30k and its been fine through 400, 460 and blowing up. Hoping it will be ok in my cars next iteration.
Small update. I slapped some new wheels and tires on the car and the fenders are getting rolled. I hope to stay within factory camber specs and still clear. We'll see!
-Acree
-Acree
I have also started tuning the car on 93 oct myself with KevinD's guidance. After I am happy cutting my teeth on MAF, I'll move to SD on 93, and then go for broke with SD on E85. We might go a little higher than 33psi if the car picks up good hp/lb.
-Acree
-Acree
those rims look sick dood! i have the same color evo, but i have a set of orange work emotion rims that will be going on it. i should be in dfw around mid may, and hopefully the car will be there late may, or sooner. gonna find out first hand what evoD offers
its a lot more common then you would be lead to believe reading stuff on evom (and maybe take it as a precaution on your own build... if your budget is tight, you shouldn't be shooting for 600+whp).
when someone posts huge HP numbers, says they are going to go run x.xxx time at the drag strip then disappears entirely, its usually because they had a failure.
another great excuse is they have a big hp cars, then they want to "take it down to change the setup". thats code for, something broke.
