Acree's MAP 2.4L FP Black Build
Old Jun 28, 2011 | 03:23 PM
  #421
Acree's Avatar
Originally Posted by chkmgnt59
So was it the flywheel after all? How would this cause the metal shavings you found in the oil?
They pulled the transmission and confirmed 3 of the bolts had backed out. A new flywheel is getting put on and the transmission is getting rebuilt.
KevinD attributed the metal shavings to break-in. He said there weren't shavings or chunks in the oil pan, just fine particles. We'll see how the filter looks in another 1000 miles.
-Acree
Old Jun 28, 2011 | 05:10 PM
  #422
RSMike's Avatar
-Acree
When i ran in my car, i used run in oil for my first 2 fills.
One was 10mins on the dyno, another for 1 hour.
They both looked like metallic paint from the run in.
Straight onto Synthetic Motul 300V after that
These "shavings" you have, were they in the filter? mine particles from run in was not visable in/on the filter, it was just in the oil that was drained out.
Cheers, Mike
Old Jun 28, 2011 | 06:25 PM
  #423
chkmgnt59's Avatar
Damn lucky break. Not bad to go from selling it all to new flywheel and back terrorizing the streets. Congrats
Old Jun 28, 2011 | 07:11 PM
  #424
KevinD's Avatar
Cheers, Mike
From taking the oil pan off and cutting the filter apart, there no shavings. The oil did have the metallic paint coloring to it Which like you said is attributed to break in on a new motor
Old Jun 28, 2011 | 08:27 PM
  #425
SmurfZilla's Avatar
I might be regretting this later down the road, but yes I plan on keeping the car.
-Acree
LOL. Enjoy the damn car. You won't regret. You put the money time and patience in it. You need to enjoy that B!tch
Old Jun 28, 2011 | 10:43 PM
  #426
Acree's Avatar
I completely agree with that statement.
-Acree
Old Jun 28, 2011 | 11:01 PM
  #427
evilempire76's Avatar
Good thing it worked out for you. Who's doing the tranny rebuild?
Old Jun 29, 2011 | 06:59 AM
  #428
Acree's Avatar
For now, I'm going with a local re-builder. KevinD can supply more information. Nothing is getting upgraded, just replaced with OEM equipment. I was having issues with fifth grinding and difficulty getting into fifth and reverse at all speeds.
::EDIT::
It is worth noting, when the knocking first occurred, I pulled the oil filter and found crap in it. It would be more appropriate to call it "metallic paint coloring" as KevinD said. It looked liked a 6 year old poured a cup of glitter in the oil.
-Acree
Old Jun 30, 2011 | 04:10 PM
  #429
Acree's Avatar
Small update: I will be adding the following items to improve feel of the transmission.
Torque Solution - Shifter Base Bushing Kit
Torque Solution - Shifter Cable Bushings
Torque Solution - Billet Aluminum Front Engine Mount
-Acree
Old Jul 4, 2011 | 01:58 PM
  #430
PlanoEvo's Avatar
-Acree
Not sure about torque solution but I got the works cable bushings which are a stiff poly that results in a non clunky shifter which you will have with solid metal bushings.Just checked their site nice stuff!
Old Jul 4, 2011 | 02:22 PM
  #431
mirkendargen's Avatar
-Acree
for solid bushings and front engine mount. They cleaned up my shifting a ton from stock.
Old Jul 4, 2011 | 02:58 PM
  #432
mitsuorder's Avatar
You cannot beat the metal shifter cable bushings. Might want to consider blocking off that oil cooler during break in as it's going to hold onto a lot of that debris that you are seeing go through the engine which could dislodge later on down the road. After your run in cycle is over hook it back up and send a sample off to Blackstone for piece of mind. On a final note some ARP flywheel bolts might be a worthwhile investment. Good luck with everything man and give North Texas some Hell!
Old Jul 4, 2011 | 10:20 PM
  #433
Acree's Avatar
Cliff notes: Built Shep 5-Speed going in.
I plan on doing just that sir. There is a CL63 and CTS-V Coupe that both want a run here locally. I'll be having some fun for sure.
Another change in plans, KevinD notified me the local guy here is delayed a few weeks on turn around and Shep can get it back in 1.5-2 weeks. I decided to go ahead and get the transmission built. Might as well do it while it's out right? The transmission in my car is a stock Evo VIII transmission that English Racing installed after the previous owner grenaded the stock Evo IX trans. I want each gear to be as tall as possible with the stock final drive ratio. Thankfully, every VIII gear is longer except for 1st. Therefore, the new trans will have everything shep puts into their "Street-Strip" build, plus Evo IX 1st and full ISF treatment. All of this plus the solid bushings should make this car a dream to drive. Or at least I'm hoping.
-Acree
Old Jul 4, 2011 | 10:33 PM
  #434
mitsuorder's Avatar
I think the do it once and do it right idea is spot on man You changing the final drive or keeping the 4.56?
Old Jul 4, 2011 | 10:47 PM
  #435
Acree's Avatar
Definitely keeping the stock final drive in. I don't feel like adding another grand to the price tag. This transmission is already delaying my wheels and tires. Still rolling on the stock Enkie's with 225/35/17's all the way around. (Thanks again, to the previous owner)
-Acree
