Acree's MAP 2.4L FP Black Build
Old Oct 2, 2010 | 11:11 PM
  #271
Acree's Avatar
It's alive! The car started up tonight around 10pm on a SD base map. I'm tired.
-Acree
Old Oct 3, 2010 | 06:21 AM
  #272
dyezak's Avatar
If you decide to go for a drive today, don't forget NTEC is having our Dyno Day todat at Cobb in Plano. It would be cool if you brought the car
Old Oct 5, 2010 | 08:23 PM
  #273
920rs's Avatar
whats up with the car man, anymore snags?
Old Oct 5, 2010 | 08:35 PM
  #274
Acree's Avatar
It's running and idling well. I've only put about 0.5 miles on it. I need to check it over tomorrow and throw the front bumper on. I have two tests this week and other stuff going on.
-Acree
Old Oct 5, 2010 | 10:19 PM
  #275
PlanoEvo's Avatar
Awesome brother
Old Oct 6, 2010 | 06:35 AM
  #276
Kracka's Avatar
Glad to hear it's running! Did you crack your valve cover? I saw you're looking for a new one.
Old Oct 6, 2010 | 07:12 AM
  #277
Acree's Avatar
I did. It seems the adapter plate for the Kiggly HLA makes it sit up a millimeter or two higher. I tightened an inside bolt by the cam angle sensors and it cracked the valve cover. It's JB Welded for now, but I need to buy another one in the next week or so.
-Acree
Old Oct 6, 2010 | 07:18 AM
  #278
RockmanX's Avatar
nice work man
Old Oct 6, 2010 | 07:57 AM
  #279
SDevo13's Avatar
Good to hear you are up and running! (and Goodluck on the tests and stuff )
Old Oct 6, 2010 | 08:44 AM
  #280
tscompusa2's Avatar
be careful with starting it up and turning it off right away. you should follow ams break in guide + mototuneus thats what I did this time and got way more power then before at lower boost levels. break in is crucial. If you warmed the car up and drove it like a baby you'll never get the most power out of your setup as you should.
Old Oct 6, 2010 | 10:29 AM
  #281
Acree's Avatar
I'm assuming your talking about these break-in procedures?
MotoTuneUSA
AMS
-Acree
Old Oct 6, 2010 | 06:49 PM
  #282
tscompusa2's Avatar
yep. cept i used 20w50 and changed 15 miles, and will be changing again at 150 miles, and then 500 miles then leaving that in until 1500 and then switching to synthetic.
Old Oct 7, 2010 | 08:27 PM
  #283
Acree's Avatar
Did a compression test today after I blew a freeze plug out of the back of the block last night. The motor had 20.2 miles on it. I was doing a 50% throttle pull around 5500 rpm and it just popped.
The compression test came out from 1 to 4, as 120, 118, 142, 145. I believe I compromised the head gasket after taking the head off and reinstalling. I will be pulling the head, back off, checking the bore and deck height of the block, checking the flatness of the head, replacing the head gasket, and reinstalling everything. This car is becoming more of a pain in the @ss than I ever anticipated, but I guess that's the price you pay for doing most of it yourself for the first time. Live and learn.
-Acree
Old Oct 7, 2010 | 08:37 PM
  #284
tscompusa2's Avatar
delete lol.
Old Oct 8, 2010 | 06:35 AM
  #285
binky's Avatar
-Acree
Ouch.......sorry man
Keep it going - you'll be happy once its done !
-Bink
