Acree's MAP 2.4L FP Black Build
Old Aug 4, 2010 | 01:08 PM
  #121
RSMike's Avatar
thanks to JB for this pic
i'll be copying it and doing the same thing
Here is my mivec oil feed filter assembly that i just got fixed up
hope that helps
Old Aug 4, 2010 | 01:12 PM
  #122
Acree's Avatar
So that braided line is the stock MIVEC oil feed line?
And THANK YOU! for your help. I am highly grateful for the quick reply.
-Acree
Old Aug 4, 2010 | 01:21 PM
  #123
RockmanX's Avatar
WOW im so glad I own a evo 8 LOL dont have to worry about that haaa
Old Aug 4, 2010 | 05:45 PM
  #124
Saleentones's Avatar
The benefits of Mivec outweigh the troubles of getting the 2.4 block to accept the feed IMO
Old Aug 4, 2010 | 06:10 PM
  #125
RSMike's Avatar
agreed.
I'm happy to gain 400-500rpm in spool and 40+hp in the top end for a little fussing with oil lines and wiring.
-Acree
Yup that line feeds into the Mivec control solenoid.
The stock line is a solid type, similar to the oil feed line for the stock turbo.
No worries!
Old Aug 4, 2010 | 07:07 PM
  #126
RockmanX's Avatar
ok if you guys say so lol put cams in the evo 8 bam there you ok but ok
Old Aug 4, 2010 | 07:39 PM
  #127
Nope, not bam... Mivec>Non Mivec, quicker spool is a fact, it's not arguable.
Old Aug 4, 2010 | 07:48 PM
  #128
RockmanX's Avatar
ok sure
Old Aug 4, 2010 | 07:51 PM
  #129
RSMike's Avatar
only if your tuner knows what he's doing
Old Aug 4, 2010 | 08:59 PM
  #130
Acree's Avatar
ok sure
Evo8 fanboy!
-Acree
Old Aug 4, 2010 | 09:07 PM
  #131
RockmanX's Avatar
Evo8 fanboy!
-Acree
i could buy a evo 9 if i felt like it but why my 8 is faster
Old Aug 21, 2010 | 03:20 PM
  #132
Acree's Avatar
Small update.
The head, IM and EM are currently being ported at MAP.
Final engine assembly should be complete this coming week.
Just took my fuel pump assembly out, ready to be shipped to Buschur on Monday.
I'm also going to be adding an ETS UICP, black powder coat with black couplers.
A Synapse BOV will be attached to it.
-Acree
Old Aug 25, 2010 | 11:00 AM
  #133
Acree's Avatar
There appears to be an issue with getting the Howard Rods in on time, so I will be switching to the Manley Turbo Tuff I-Beams. I'll be running with the lighter 14400 series. They run 637g which is right in line with the Howards, so 9k shouldn't be an issue with this build.
There is also an issue running a high lift cam with the stock retainers, so I will be running the GSC Beehives with Ti retainers.
Original post updated.
-Acree
Old Aug 25, 2010 | 08:39 PM
  #134
awddyno's Avatar
Very nice build. I should be right behind you very soon. I just hate to take the car apart when its my only ride now.
Old Aug 28, 2010 | 03:27 PM
  #135
Acree's Avatar
The intake manifold, exhaust manifold, oil pan, windage tray, oil pick up tube, FIC 1450 injectors, cam gear, Omni 4-bar MAP sensor, and misc gaskets came in today.
The porting on the IM and EM look great. It's a superb job. I was able to reassemble the entire IM today with injectors, fuel rail, EGR components etc.
Now just waiting on the head and the block. As of yesterday, the turbo is still waiting at FP for parts. The fuel pump assembly is waiting on parts at Buschur also. Hopefully these two delays won't take too long.
-Acree
