Acree's MAP 2.4L FP Black Build
Picked up the black today from FP. Its getting ported tonight along with the MAP dump housing. I'll be waking up early tomorrow and will get everything back together.
-Acree
-Acree
I've had a good number of set backs... and I'm still afraid that there will be no compression when I try to start it in a little bit. I did a leak-down test, but it was rather inconclusive. All cylinders "kind of" held pressure. They lost air at a constant rate and its coming from the crank case. I'll update later tonight.
-Acree
-Acree
99% chances it's the timing. I'll know tomorrow once I pick up a decent timing tensioner tool. 1% chance MAP didn't alternate the piston rings when the block was assembled. That's very unlikely.
-Acree
-Acree
