So you have Meth Injection.. Are your pistons also cracked??
Old Jul 6, 2010 | 05:53 PM
  #46
AWD Motorsports's Avatar
Originally Posted by meat_EVO
460 on straight pump? what other suporting major mods? Just curious.. cams im sure.
and are you talking about the guy that moved to VA? and had the mishap whit his BR built motor?
Yes thats correct the built motor car.. We have made 420 on stock motor no cams.. Still 93 pump.. Car is running like a champ..
Mike
Old Jul 6, 2010 | 05:56 PM
  #47
meat_EVO's Avatar
Mike
I cant wait to get his car on our local dynojet and see is all the rumors are true about the Florida Dynos reading higher the the rest of the world. We shall post results
and im sure you could easily see 420whp on pump, but i am by no means a pro tuner, and this is all me tunning.
Old Jul 6, 2010 | 05:59 PM
  #48
If it reads higher by a significant amount ill paypal you 500.00..
Our cars with less than 800hp on our dyno run 8s.. 460hp ran 10.6 in a full street car.. and my evo X with 350hp ran 11.8.. so Have at it bro.. Dyno it for me please..
Matter of fact ours reads very close to Sean Iveys Dynojet in NJ also..
Mike
Old Jul 6, 2010 | 06:00 PM
  #49
Ted B's Avatar
Originally Posted by Svendiesel
I have! The problem is this. A: I cant fit another car in my driveway between mine, my moms and my dads cars. ... B: I cant really afford to put another car on the insurance between all of my other monthly payments. ...
It would seem that you are playing an expensive, potentially crippling game of Russian Roulette being this is your only means of transportation. I think the unavailability of E85 is perhaps among the least of your concerns.
That does happen on occasion here too.. Some stations dont allow it...
One local hot rodder went so far as to get a replacement "Flex Fuel" emblem from a Chevy dealer and stick it on the back of his car. That shut them up.
But seriously, over here, the only cars I see filling with E85 definitely aren't flex fuel GM grocery getters!
Old Jul 6, 2010 | 06:11 PM
  #50
goog49's Avatar
hey guys, i'm pretty much brand new to the forum. a few of my friends are long time members so here i am. anyway, i got the aem meth set up which seems to be working great so far. has anyone had any problems with their o2 sensors going out after installng their meth kit? i went from like 20mpg to like 11mpg. any thoughts...?
Old Jul 6, 2010 | 06:13 PM
  #51
Ted B's Avatar
Methanol does not adversely affect O2 sensors. If you are getting 11 mpg in average driving, you definitely have a situation on hand.
Old Jul 6, 2010 | 06:27 PM
  #52
wizzo 8's Avatar
Yea if anything you should have better MPG
Old Jul 6, 2010 | 06:30 PM
  #53
meat_EVO's Avatar
i would not say that, the car is still using teh same amount of fuel under daily driving because meth is now always flowing. and with the new found HP he may be driving more aggressive simply because it more fun... resulting in ****ty gas mileage. LOL
Old Jul 6, 2010 | 06:42 PM
  #54
wizzo 8's Avatar
First part is true but when under boost the meth is a secondary fuel which should lower the amount of pump fuel used. Im getting about 19-20MPG and Im in boost a lot more now with my power levels. Even use the A/C sometimes. This is suburban driving
Old Jul 6, 2010 | 07:04 PM
  #55
94AWDcoupe's Avatar
I agree meth injection is very risky. I dont doubt for an instant that AWD has seen more blown motors from meth than any other fuel. But blaming it on poor distribution per cylinder is 100% incorrect diagnosis.
looking at blown 4g63s for years. if engine doesnt have meth no 2 will blow first. followed by no 4. no1 will be least likely to blow. Its because air doesnt distrubute equally due to intake manifold design. Then when you run meth the air is now filled with meth so order of cylinder mixture reverses in order.
lean to rich=
no meth 2, 4, 3, 1
with meth 1, 3, 4, 2
DSM link for early 4g63 cars has a nice feature where you can watch knock noise of all four cylinders. The noise tables 100% confirms this.
People who run meth are budget minded builders. so the tune gets short changed. if system is reliable and tune is spot on 93/meth motors perform as well as any other.
Old Jul 6, 2010 | 07:09 PM
  #56
lean to rich=
no meth 2, 4, 3, 1
I disagree.. The same has been seen for years with Nitrous Wet kits..
Explain why 1 CYL ONLY.. The car ran for a long time to have the carbon build up on the cracked piston so if they blow in order what is it like 1 year in between each failing?? Why are the other 4 not melted AT ALL, not cracked and in good shape..
I also disagee that 93 Meth motors perform as well as any other.. Waiting to see 93/meth cars run 8s like E85.. And will be waiting along time to ever see that..
I am also curious how you can attribute this to intake manifold design when you dont know what intake manifold was even on the car.. it also goes against what dave buschur found on the flow bench during intake manifold testing..
Mike
Old Jul 6, 2010 | 07:23 PM
  #57
94AWDcoupe's Avatar
nitrous wet kit would be same as no meth car. nitrous is adding a ton of oxygen and a little extra fuel.
lean to rich 2 4 3 1 remains as no meth car
I have seen far more blown motors than you. and i have used 93/meth succesfully for 50,000 miles on my cars over the years.
Never said 93/alky will make same power as e85. stock engines run/perform well. runs/peforms well is key.
Old Jul 6, 2010 | 07:26 PM
  #58
Never said 93/alky will make same power as e85. stock engines run well. runs well is key.
Your opinion and my opinion are different.. well leave it at that..
Mike
Old Jul 6, 2010 | 07:42 PM
  #59
Evoryder's Avatar
pics of other pistons?
Also I believe lack of a purge button/ switch is crucial in proper operation of meth.
Old Jul 6, 2010 | 07:44 PM
  #60
94AWDcoupe's Avatar
I will leave it at your opinion and my knowledge are different
