Best size intake for 35r?
Old Jul 12, 2010 | 12:04 PM
MrHouse's Avatar
What is the best intake to use for 35r? I have been using stock pipe with perrin filter on my stock turbo. Shall I stick to the stock pipe or change to something like samco. What size is the samco intake?
Old Jul 12, 2010 | 12:13 PM
JakeTheVIII's Avatar
Not sure how you would fit a stock intake tube on a 35R. For example, my 35R has a 4" inlet. So, I'm either going to use a 4" to 3" adapter with a 3" straight pipe (with MAF adapter plate and filter), or a straight 4" pipe with filter on it.
Old Jul 12, 2010 | 01:07 PM
OneCrzyEvo21's Avatar
Convert to SD..Awesome power gains on large frame turbos..
Old Jul 13, 2010 | 02:45 PM
raasfaas's Avatar
I would strongly recommend going with a 4" intake for your setup and definitely consider switching over to SD. When I tried the 4"-3" reducer and ran a straight 3" pipe it caused a huge restrictions at the inlet. As soon as I removed the intake pipe I gained 35hp on a back to back run with and without the pipe.
Old Jul 13, 2010 | 02:47 PM
^^^^ He is correct..makes a world of difference on large frame turbos..
Old Dec 27, 2010 | 08:41 AM
MrHouse's Avatar
Went with AMS intake kit and it does not fit. Filter is too long for MAF setup. AMS should look into it. Anyone aware if Buschur or ETS one is of correct length?
Old Jan 5, 2011 | 08:42 PM
hboy7777's Avatar
3 or 4" should be fine
Old Jan 19, 2011 | 07:23 PM
mrboost05's Avatar
get a shorter filter ? i no the older ams ones use longer filters buschur sells a really nice filter its the same one that comes with his FF kit its kinda pricy tho.
steven121
Sep 12, 2012 08:36 AM
PlanoEvo
Mar 17, 2009 06:40 AM
BoostWhore
Dec 8, 2005 09:47 AM
silvrevo
13
Aug 18, 2004 07:30 AM
EVO VIII Chris
Jun 30, 2003 03:01 AM
