ACL or Clevite Rod Bearings???
Old Jul 15, 2010 | 12:34 AM
SOEuro's Avatar
i searched...
Is there a big difference in these two,im looking at getting Rod and Main bearings for my build,Ill be pushing under 500hp on a 2.0
which bearings did you guys go with and why??
thanks Stone
Old Jul 15, 2010 | 01:57 PM
SOEuro's Avatar
Ttt
Old Jul 15, 2010 | 01:58 PM
MN_Evolution's Avatar
Clevite are technically better quality, but ACL's work fine. Especially if you will be below the 6-700hp mark.
Old Jul 15, 2010 | 02:07 PM
Acree's Avatar
Do you have any proof or material showing this? If this is true, why do most people use ACL?
I would like to know since ACL's are on backorder. It would allow MAP to get started on my build faster.
-Acree
Old Jul 15, 2010 | 02:15 PM
-Acree
Most people use ACL because the difference (imo) is less than noticeable. And the ACL's are cheaper.
You would be a-okay with either one.
Old Jul 15, 2010 | 02:20 PM
OneCrzyEvo21's Avatar
I used ACL Rods and Clevite Main bearings w/ Cosworth Thrust washers..they all awork..as long as the clearances are correct.
Old Jul 15, 2010 | 02:34 PM
SOEuro's Avatar
awesome,thanks guys
Old Jul 15, 2010 | 09:20 PM
reactionevo8's Avatar
lol...ive used acl's on countless builds..a couple of which were beyond the 800whp level...they are a great bearing...that being said,ive also used clevite bearings with great results...in my experience i dont really think one is better then the other...
EDIT...fwiw they are very close in pricing as well
Old Jul 16, 2010 | 01:02 AM
Yeah, there's really not a noticeable difference in the two besides price and availability.
Old Jul 16, 2010 | 12:42 PM
20gmr's Avatar
use oem. and get the select fit numbers off your block.
babaz7
34
Oct 13, 2017 04:57 PM
talonkev
May 9, 2017 05:43 AM
2006GSR
Mar 11, 2016 08:54 AM
Dannievo
16
Apr 26, 2015 08:54 PM
ryans1000
26
Mar 5, 2014 07:20 PM
