FYI - evo6 vs evo9 headgasket
Old Sep 2, 2010 | 10:46 PM
RSMike's Avatar
here are a couple of pics of each
Both are genuine Mitsubishi parts
The ridges inbetween the cylinders on the evo 9 gasket are proud and point out.
The ridges inbetween the cylinders on the evo 6 gasket are sunken.
There are various water/oil galley changes, 2 of them being completely blocked on the evo9 (at the bottom).
If anyone wants anymore pics, lemme know.
Cheers, Mike
Old May 4, 2011 | 11:53 PM
fugiwara's Avatar
I know that evo9 has improved coolant passage.
Old May 5, 2011 | 02:32 AM
jameswwt's Avatar
Cheers, Mike
Speechless Info again
Old May 5, 2011 | 02:43 AM
RSMike's Avatar
improved where?
in the head?
if so, that is false
source: http://www.motoiq.com/magazine_artic...ided-by-8.aspx
Old May 5, 2011 | 02:48 AM
jameswwt's Avatar
Wow! I ever wonder do Mike sleep??? hahahaha
Old May 5, 2011 | 03:29 AM
RSMike's Avatar
i'm on the other side of the world buddy
and i'm sick at the mo, so i'm not at work!
Old May 5, 2011 | 04:11 AM
jameswwt's Avatar
Wow! Then you have to checkout our Malaysia Island vacation...
Beautiful island for snorkeling & diving...
Can check out my island holiday pictures via my FB (jameswwt@hotmail.com)...hahah
I bet if you like Malaysia then we can setup a workshop here....hahaha
Old May 5, 2011 | 04:45 AM
4RETECH's Avatar
Wow, thanks for the info.
Old May 5, 2011 | 08:23 PM
8000rpm's Avatar
Thank's Mike
Old Nov 4, 2019 | 06:14 AM
knox839's Avatar
Thickness
pictures did not open. Can you write the thickness please?
Cheers, Mike
Old Nov 15, 2019 | 09:04 PM
mazdabish's Avatar
I measured my Evo 9 headgasket at 0.040" inches using a Mitutoyo Digital Caliper close to the rivets (not near the fire ring, it's a little thicker like 0.042-44" there possibly compressing to 0.040-41" once torqued down on the engine). Felpro also lists their equivalent for a OEM Evo 9 Headgasket as 0.045" and 0.028" for a OEM Evo 8 HG so it's likely very close.
On a similar note I bought a JE ProSeal 0.051" headgasket for $80. It looks like it could be a decent aftermarket headgasket if you don't want to spend $300 on a HKS or $150 on a Cosworth. Comes in 87.3mm for 4G64 applications too, the one I got (MI1001-051) was a 86.3mm bore. 4 Layers MLS w/a stopper layer and made in Italy. I have a feeling they're actually made by Athena Racing Gaskets (P/N 338017R looks IDENTICAL to MI1001-051 down to packaging and both gaskets have the same "features").
oofastlineoo69
Nov 19, 2012 05:10 AM
scheides
May 5, 2010 10:43 PM
precisionpsi9
Feb 10, 2009 08:18 PM
mandy1
Nov 23, 2008 08:37 PM
CarbonKrazyEvo9
Aug 27, 2008 05:52 PM
