Apexi Timer Killed Remote Lock
Old Nov 30, 2003 | 10:18 PM
HoustonEVO's Avatar
I installed my Apexi Turbo Timer today. Everything went easy (btw spend the $2 at Pep Boys and buy the wire clips for splicing like the red one they give you so you dont have to rick damagin ecu wires) but here is the problem. Now, wether the timer is still running or even after it shuts off the keyless entry does not work. I am assuming it does not b/c the timer simulates a key in the ignition. Is this normal with turbo timers and is there a wire to disconnect so I can use my keyless entry to get in and out. Thanks for any response.
P.S. I ordered my timer from Lancershop.com and service was great. Was able to order it over the phone and came right in. No waiting like alot of online companies where it ends up taking a couple weeks for stuff to come in. Hopefully they can help me with this prob too when i call them 2morrow.
Old Nov 30, 2003 | 10:28 PM
Creamo3's Avatar
Did you buy a harness with your turbo timer? If not, look into it as it can save you alot of time and wire splicing. I'm pretty sure they sell the harness for the evo, i know they had one for my gsx.
Old Dec 1, 2003 | 07:26 AM
sleet's Avatar
I bought my turbo timer and harness from lancershop, no problems yet.
Old Dec 1, 2003 | 10:47 AM
HoustonEVO's Avatar
I got the Apexi Timer and the HKS harness from Lancershop. Its all hooked up correctly. N e one have n e other ideas????
Old Dec 1, 2003 | 10:50 AM
slt's Avatar
slt
Nope
Same setup here and it works fine.
Old Dec 3, 2003 | 10:48 AM
HoustonEVO's Avatar
N E of the techs that work on EVOS have any idea?
Old Dec 3, 2003 | 10:53 AM
Jamdown's Avatar
same setup no probs.....you prob have a small mistake somewhere....
Old Dec 3, 2003 | 12:34 PM
bpclements's Avatar
Here is a circuit you can make if you have an aftermarket alarm so you can lock and arm your alarm with the timer running. I don't know if this will help, but I thought I would post it up just in case.
Here ya go.
november
17
Jan 11, 2021 06:03 AM
suicidevo
May 28, 2011 09:25 AM
Vaalie30
Jul 9, 2010 03:07 PM
Fuel53
May 25, 2010 06:06 PM
lilman8403
Feb 3, 2006 10:36 AM
