FP Green Oil Selection
Old Nov 6, 2010 | 06:48 PM
  #91
miragevo's Avatar
Veteran: Navy
Originally Posted by n2oiroc
what makes it unsuitable for an evo?
Don't we have a hard enough time choosing the right oil with out adding this?
Applications and Recommendations:
AMSOIL Formula 4-Stroke® PowerSports Synthetic Motor Oil is recommended for four-stroke engines and transmissions on two- or four-stroke powered applications. It is an all climate/all season oil that replaces 0W-30, 0W-40, 5W-30, 10W-30 and 10W-40 oils for ATVs, UTVs, snowmobiles and other power sports equipment. Manufacturers include Polaris®, Honda®, Yamaha®, Ski-Doo®, Can-Am® (Bombardier®), Suzuki®, Kawasaki® and Arctic Cat®.
Old Nov 6, 2010 | 06:52 PM
  #92
n2oiroc's Avatar
you guys are punishing yourselves too much over oil. evo motors arent picky at all. if you are that worried about problems related to oil, dont run a fp turbo. its that simple.
Old Nov 6, 2010 | 06:57 PM
  #93
wreckless969's Avatar
Or run an oil that's of high enough quality that it doesn't matter what parts you have on your car...
Old Nov 6, 2010 | 07:02 PM
  #94
n2oiroc's Avatar
i prefer to take a different approach and run high quality parts that dont require 3,000,000 ppm of zinc in a 80wt oil.
Old Nov 6, 2010 | 07:06 PM
  #95
I prefer a high quality oil that will meet all my lubricating needs and not buckle under the pressure of the more demanding apps. And for the record I love my FP Red...A LOT. And I wouldn't give it up just to run a low quality semi synthetic motor oil.
Old Nov 6, 2010 | 07:12 PM
  #96
n2oiroc's Avatar
im all for a good high quality oil, i just think threads like this cause undue stress and anxiety for a lot of people. ted posted a good list and many others have recommended oils. fyi, in my 540whp 07 sti i ran a mix of m1 0w40 and m1 15w50. i beat the hell out of that car, overrevved and overboosted it many times and it never skipped a beat. if m1 can keep a sti motor alive under those conditions an evo should run fine on crisco.
Old Nov 6, 2010 | 07:17 PM
  #97
miragevo's Avatar
Veteran: Navy
I have a problem with the way FP tested Mobil-1. They emptied out the Brad Penn 20W-50 and then put in some BS 10W-30 non synthetic oil and ran it and then they changed the oil out again with another BS fill of 10W-30 non synthetic oil.......It seems apparant that they definately wanted to flush out the Brad Penn 20W-50 with 2 oil changes of some BS brand 10W-30 non synthetic oil. But then they dumped out the BS 10W-30 non synthetic oil and then filled it up with Mobil-1 10W-30 and proceeded on with their testing.......Don't you think it would have been fair to flush the BS oil out with 2 oil changes of the Mobil-1 10W-30?? I have read that small amounts of regular oils mixed in with Mobil-1 will reduce its effects. Why didn't they try Mobil-1 15W-50 which has the same amount of zinc and more phos than the BS Royal Purple that they say is approved for the FP Turbos???? I just feel like Mobil-1 got screwed in these tests.............
http://store.forcedperformance.net/m...otor%20Oil.pdf
Old Nov 6, 2010 | 07:22 PM
  #98
n2oiroc's Avatar
did you notice motorcycle oils listed in that link that he recommends?
  #99
I doubt FP has an agenda against Mobile 1...I mean conspiracy theories aside if I recall there is some mobile one that is approved for use with those turbos.
Old Nov 6, 2010 | 07:26 PM
  #100
miragevo's Avatar
Veteran: Navy
Do you or do you not think they should have done 2 changes of the 10W-30 Mobil-1 to ensure the BS non synthetic oil was better flushed out? This is a yes or no question....please answer.
Old Nov 6, 2010 | 07:40 PM
  #101
Yes, cleaning better MAY have lead to SLIGHTLY more favorable results. But if they used a similar method across the board for all oils then it;s kinda a moot point.
Old Nov 6, 2010 | 10:18 PM
  #102
EvolutinIX's Avatar
How would I find the flash and shear point of amsoil 0w-30? Does zddp only come into play if the film breaks?
Old Nov 7, 2010 | 01:34 AM
  #103
http://www.amsoil.com/storefront/sso.aspx
Almost at the bottom of the page.
Old Nov 7, 2010 | 05:23 AM
  #104
EvolutinIX's Avatar
Thank you, is fire point and shear point the same?
Old Nov 7, 2010 | 05:30 AM
  #105
High Temperature/High Shear Viscosity cP, X°C, X s-1 (ASTM D4683)
3.2
Couldn't tell you what that means...but AMSOIL is premium so I am certain it means something good
