winter Project ''project 9'' by Evodan2004.
Old Mar 15, 2011 | 11:22 AM
  #151
SPANKED's Avatar
Are you still selling your UICP? Could you PM price shipped to 11746 NY. What color is it?
Old Mar 15, 2011 | 12:15 PM
  #152
dsmfan95's Avatar
Man I want that TRE Rear end so bad.
Build looks great Dan! Good luck buddy!
Old Mar 15, 2011 | 04:52 PM
  #153
EvoDan2004's Avatar
i still have the UICP. a member already has 1st dibs on it when it is off the car. if he does not want it then ill pm you.
thanks man. year the rear looks great. i hope it will help out at the track.
Old Mar 15, 2011 | 05:35 PM
  #154
mayberry's Avatar
What service did you get, what did it cost when it was all said and done. I'd like to get a real world estimate on it. Can't wait to see your results this year!
Old Mar 15, 2011 | 06:43 PM
  #155
EvoDan2004's Avatar
i got the works. everything on hit site. HD cover, rear cover, 12 plate upgrade and all the other specs. cost was exactly what it said on his site. i have a core charge though and i am sending him my old rear tomorrow.
the hole rear of the car is COMPLETE. everything is installed. it all looks so nice i do not think i am going to drive the car ever again.
Old Mar 15, 2011 | 06:46 PM
  #156
tscompusa2's Avatar
very nice. the rear is the only thing i didn't do on my car.. now i bet it breaks after saying this.
Old Mar 15, 2011 | 06:55 PM
  #157
EvoDan2004's Avatar
i hope not. lol
anyone want to help me real quick and peak under there car? need a hand.
look at the rear where the drive shaft connects to the rear. 4 bolts hold that up. what side is it washer and nut on. front side facing the drive shaft or rear side facing the rear diff.
lastly
look at your lower control arms. the adjustment nut that you adjust that also connects the lower control arm to the Aluminum sub frame. what way is the nut and washer facing. front or rear of the car.
other then this im done back here. thanks the the one who can take a peek.
Old Mar 15, 2011 | 07:00 PM
  #158
mayberry's Avatar
Give me five minutes. I'll tell you. My car is actually up in the air right now. lol
  #159
EvoDan2004's Avatar
awesome. thank you.
ill link you to TRE's site and what i had done.
Old Mar 15, 2011 | 07:11 PM
  #160
mayberry's Avatar
On the driveshaft, the bolts go from front to back with the washers and nuts on the back towards the rear diff. The lower control arm bolts go the exact same way. With the washers and nuts facing the rear.
Old Mar 15, 2011 | 07:14 PM
  #161
EvoDan2004's Avatar
i owe you a thanks man.
Old Mar 15, 2011 | 07:34 PM
  #162
mitsevo03's Avatar
What kind of tires are you running? I run Toyo Proxes RA1s and I drop the pressure down to around 22 or so and have had a best 60 foot of 1.49. They are a little expensive but are some damn good tires
Old Mar 15, 2011 | 07:37 PM
  #163
EvoDan2004's Avatar
WOW your the f n man. i run 555R tires and at 22psi ish i can run faster then i 60 foot this car. idk what the hell im doing wrong. haha. great 60's man. really
Old Mar 16, 2011 | 01:53 PM
  #164
EvoDan2004's Avatar
exhaust manifold, Turbine housing, and down pipe are all back from swain tech coatings.
Old Mar 16, 2011 | 02:00 PM
  #165
EvoDan2004's Avatar
here is the pics. also to add in keeping the heat in i ordered a T4 Ti DEI turbo blanket and i have DEI exhaust wrap for the DP. this should keep underhood temps DOWN.
